Colm's iray Lighting
145679
  • sapatsapat Posts: 1,735
    Jan19 said:
    sapat said:
    I mean everyone has them.  What's the big?  Yes, I know, that's a rhetorical question.
    Yes, and in some poses -- and with some characters -- NOT using real anatomy looks rather weird.  I think I'm wandering OT, though, so will wisely hush.
    Yes it's not natural, but as you said, move it along, nothing to see.......literally cheeky
  • mmkdazmmkdaz Posts: 335
    Excellent package. thank you very much for your hard work!
  • seeker273seeker273 Posts: 449
    edited May 2016
    JazzyBear said:
    seeker273 said:
    Thanks Jan19, I love them so much. I always get a good result with them. Colm also has some tutorials on youtube, I learned a lot of things about lighting!
    Love your Artwork!
    Are you doing post work to get the "illustrated" look to them?
    Thank you! :) I always do some sharpening and level/color correction in my images, some need a little most postwork than others but that's the main actions in all of my renders. Unfortunately I don't have an NVidia card so all of my renders in DS come out grainy so I also have to use some denoise, so they get softer than I want them to :( I think that's what's giving them the more illustrated look.
    Here's the straight render and the postworked.
    P.S. Forgot to add the magical dodge tool, it definately helps to give it that look. I use it for some highlights om the hair and skin.
    758 x 1000 - 140K
    737 x 960 - 548K
    Post edited by seeker273 on
  • Jan19Jan19 Posts: 1,109
    edited May 2016
    Touche. smiley  That word doesn't look the same w/o the accent mark.
    At the risk of wandering OT again -- does the video card affect render quality?  I have an AMD, and it bites to use the Aux window because the update gets slow sometimes.  But I thought CPU renders were the same as renders made w/an NVidia card.  Is that not right?  (I'm debating more memory versus new video card, and have been for months now.) :-)
    Post edited by Jan19 on
    As far as I know there's no quality difference between the GPU and CPU renders. It's just a matter of how much time it takes. It's not long that I got my AMD, but if I'd known I'd start using DS so much I'd absolutely go for the NVidia option.
    edited May 2016
    Oh, the render time factor!  I see. smiley​  Gotcha.  Thanks.
    Yes, me, too.  If I'd known about IRay and NVidia when I got this rig, I'd have gotten a different video card, too.  Now I wonder if installing a new card might not void the warranty.  But anyway, thanks, again.  :-)  I thought it was fine to render w/CPU -- just not as fast.
    Back to Monochrome -- I thought I'd never get the right look for this one -- and after I posted it, I saw a lighting change I'd like to make.  Render and learn, I guess.
    Monochrome is a challenge, but I like it. :-)
    http://www.daz3d.com/gallery/#images/149016/
    Back to Monochrome -- I thought I'd never get the right look for this one.  Monochrome is a challenge, and I like it! :-)
    Jan, that is really a smashing render!
    I have an Nvidia card....but it's 2 yr old, so not the latest and most powerful.  GeForce GTX 760 which has 3GB memory I think.  I get decent render times with Iray, but it depends on hair and size of textures too.
    Thank you, sapat! smiley
    After I post a render in the gallery, inevitably I'll see that one last thing that I didn't tweak.  This time it was "face needs more light and chest less."
    I'm still learning lighting. :-)
    But thank you very much!!!
  • nelsonsmithnelsonsmith Posts: 1,337
    Just discovered this guy through another thread, and he does excellent tutorials.  If i wasn't broke, I'd have his products right now.  Trust me they are  on the wish list and will be mine sooner rather than later.
    Sure does. :-)  And I hope sooner comes for you very quickly!  (I would say 'soon,' but there's the thing about 'DAZ soon.') laugh
    I love the scenes.  Only thing is, I feel like I'm cheating a bit if I use them.  I have no idea why; that's what they're there for.
  • JazzyBearJazzyBear Posts: 805
    Thanks for the info Seeker. Every now and then I want a more illustrated look and ahve a ahrd time getting it. Really more of a 2d illustrated than a comic book look.
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,983
    Question about the monocrome set. Does your scene automatically render black and white or are there manual settings? Also can the same scenes be done in color as well?
    edited June 2016
    Yes, you can render your scenes in color.  There are manual settings to change from black and white.
  • Loading one of the light preset "scenes" will render in color, but there are 6 presets, (3 low contrast, 3 high contrast), that will set everything up to render black and white.  If you change your mind and want to go back to color - or to render with a hint of color - simply go to the Render Settings pane > Tone Mapping and change the saturation valu anywhere from 0.xx to 1.0 and you should be able to manipulate the results as you desire.  So, very little manual tweaking necessary.  :)  Since the lights are set to look best in B & W, you may need to tweak their values if you choose to go back to color.  It's all in the look you want to obtain, but it is a very useful and versatile set.  :)
    I didn't know that -- I thought the scenes defaulted to b/w.  Thanks for the heads up. smiley
    Yes, once you click on one of the render settings of High/Medium/Low Quality located under either High Contrast or Low Contrast, it changes the Iray environment settings from 'Dome and Scene' to 'Scene Only', and the Tone Mapping Saturation down to 0.00. (It also will change the Burn Highlights and Gamma depending on if you use High Contrast or Low Contrast as well.)
    1085 x 552 - 104K
    729 x 533 - 67K
    edited June 2016
    I'd figured out the Saturation part, but didn't know how the Contrast was changed.  I always change the Contrast using settings from another product.  Well, not always, but if I wanted in-between for a color render.  Good to know all this. :-)
    Thanks so much for all the help, I really love this set
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,555
    edited June 2016
    used both render studio and render studio iray scenes for this one
    http://www.daz3d.com/gallery/#images/158671
    Post edited by Chohole on
    Yeah, right on!  Who doesn't love a girl band?!  Very cool image and lighting!!
  • WonderlandWonderland Posts: 7,133
    edited June 2016
    My first experiment with Colm's lighting. I added a yellow hue to one of them which might look a bit weird on the hair, but I like things a bit arty... It is also my first experiment with Rune and I added morphs from Handspan's Genesis 3 morphs 3...
    834 x 1080 - 655K
    Post edited by Wonderland on
    Great images! smiley  I really like all the color.
  • fastbike1fastbike1 Posts: 4,078
    Re Monochrome:
    While it is nice to be able to render in monochrome, the rendering controls / options for monochrome are really limited within Studio. You will need to do postwork if you want anything more than a simple desaturated render.
  • BeaBea Posts: 753
    I think the thing that is really great about Colm's items is that they are a complete package that you can get good results with straight out of the box :)
    Great renders everyone :)
    edited June 2016
    I always tend to like the black and white versions better... I have only experimented with like 0.0001% of the lighting sets, but I'm really liking them so far. And thanks to watching Colm's videos, I learned about creatind a small AUX viewport to see the lighting in real time. That was one of those most confusing things to me...
    720 x 1080 - 364K
    Great renders everyone!  Love the intensity of the colored one as well smiley  The Aux viewport is an amazing tool that I'm happy to have in my back pocket now thanks to Colm bringing it to my attention.  I never got into the Nuts n Bolts of all DS can do, but learn bit by bit when someone presents it to me.
  • MuzeMuze Posts: 182
    Great job Colm! And great renders everyone. I'm totally impressed.smiley
    thank you yes the lighting really helps as well as the cove backdrop tried this scene with a theatre and stage but this setup was much better
    she is very versitile Wonderland, like the lighting highlights in her hair in both renders and the backdrops make her stand out
    edited June 2016
