Transfer Utility bug
IsaacNewtonIsaacNewton Posts: 1,300
I am trying to transfer genesis 3 female rigging onto a clothing object using the Transfer Utility which is accessed via Edit:Figure:Transfer Utility in the main menu or the pull down menu in the scene tab: Assets:TransferUtility.
I used the tutorial here:
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/rigging/tutorials/transfer_utility/start
This is the process I followed
1) Load genesis 3 female
2) Zero genesis 3 female figure
3) Import SummerDress object (obj file prop made in Marvelous Designer 5) (see attached image)
4) Convert Summer Dress object to SubD
5) Select Transfer Utility in Scene menu pull down
6) Fill in options and press Accept (see attached image)
This always leads to the same error message. (see attached image)
I have repeated my attempts to transfer rigging from g3f on to different clothing items on several occassions (after restarting the computer... which has specs more than sufficient for the task) but the process always gives the error message.
I reported this bug to Technical Help a week ago but I have not even had an acknowledgement reply yet, so I am not holding my breath for a quick solution. Perhaps they are very busy.
Has anyone else experienced this problem? Is there anyone who knows of a solution?
Relevant info: Using DS4.9.2.55 on Windows Pro 7 64bit, 2x Nvidea 980GTX video cards, i7 processor, 64GB RAM
Post edited by IsaacNewton on
  • IsaacNewtonIsaacNewton Posts: 1,300
    ah ha.. just got an acknowledgement reply... "..will get back to you as soon as...."
    Cool.
    In the meantime... does anyone else have any comments?
  • Richard HaseltineRichard Haseltine Posts: 109,264
    If your images are going to show bare nipples please switch to Smooth Shaded view rather than sticking a blocker on to cover them.
    Have you checked the log file (Help>Troubleshooting>View log)? The error will be at the end if you open the log just after trying to run the transfer.
    Returning quicky to the subject...yes, but the error message is coded:
    2016-49-21 21:49:37.463 Loaded file: KikiY_SummerDress01.obj
    2016-49-21 21:49:57.154 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2016-52-21 21:52:09.968 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    edited May 2016
    None of those appear related to the Transfer Utility on the face of it. You could try removing the textures from the OBJ, and possibly not converting to SubD before doing the transfer.
    I had previously exported just the obj file and also not converted to SubD but the results are the same. I will do this again and report back the error message in the log file.
    Using a dress object with no textures and not changing the object in any way, I ran the Transfer Utility from the Main menu and got the same error pop up. The log records the following:
    2016-04-26 00:04:46.667 File loaded in 0 min 7.2 sec.
    2016-04-26 00:04:46.670 Loaded file: genesis 3 female.duf
    2016-04-26 00:04:46.826 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2016-04-26 00:04:47.147 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-04-26 00:04:47.147 Loaded file: PHMMouthRealismHD.dsf
    2016-04-26 00:04:47.157 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-04-26 00:04:47.157 Loaded file: PBMNavel.dsf
    2016-04-26 00:04:47.561 Loaded image ryjeane_arms_1004.jpg
    2016-04-26 00:04:47.647 Loaded image ryjeane_mouth_1005.jpg
    2016-04-26 00:04:47.869 Loaded image ryjeane_face_1001.jpg
    2016-04-26 00:04:48.093 Loaded image ryjeane_torso_1002.jpg
    2016-04-26 00:04:48.300 Loaded image ryjeane_legs_1003.jpg
    2016-04-26 00:04:48.388 Loaded image ryjeane_eyes01_1007.jpg
    2016-04-26 00:04:48.455 Loaded image ryjeane_eyerefl01_1008.jpg
    2016-04-26 00:04:48.539 Loaded image ryjeane_lashes_1006.jpg
    2016-05-26 00:05:49.518 Performing figure transfer:
    2016-05-26 00:05:49.985 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-05-26 00:05:49.986 Loaded file: pJCMThighTwist_n75_L.dsf
    2016-05-26 00:05:49.990 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-05-26 00:05:49.991 Loaded file: pJCMThighTwist_75_R.dsf
    2016-05-26 00:05:49.998 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-05-26 00:05:49.999 Loaded file: pJCMThighSide_85_R.dsf
    2016-05-26 00:05:50.004 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-05-26 00:05:50.005 Loaded file: pJCMThighSide_85_L.dsf
    2016-05-26 00:05:50.010 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-05-26 00:05:50.010 Loaded file: pJCMThighFwd_115_R.dsf
    2016-05-26 00:05:50.016 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-05-26 00:05:50.017 Loaded file: pJCMThighFwd_115_L.dsf
    2016-05-26 00:05:50.022 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-05-26 00:05:50.022 Loaded file: pJCMThighBack_35_R.dsf
    2016-05-26 00:05:50.028 Loaded Morph Deltas in 0 min 0.0 sec.
    2016-05-26 00:05:50.029 Loaded file: pJCMThighBack_35_L.dsf
    2016-05-26 00:05:50.029 Error projecting skin binding during figure transfer.
    I repeated this using the Transfer Utility via the Scene Tab menu (Assets:Transfer Utility) and the same error occured. The log shows:
    2016-11-26 00:11:05.857 File loaded in 0 min 12.1 sec.
    2016-11-26 00:11:05.963 Loaded file: genesis 3 female.duf
    2016-11-26 00:11:44.006 Performing figure transfer:
    2016-12-26 00:12:44.738 Error projecting skin binding during figure transfer.
    I assume this relates to the same error
    I have repeated the process after removing all textures from the genesis 3 figure. The result was the same, the log reads:
    2016-16-26 00:16:20.163 File loaded in 0 min 23.4 sec.
    2016-16-26 00:16:20.235 Loaded file: genesis 3 female.duf
    2016-17-26 00:17:18.701 Performing figure transfer:
    2016-21-26 00:21:25.084 Error projecting skin binding during figure transfer.
    Yes, the projecting skin binding error would be the Transfer Utility. Try it with no Projection Template set.
    Yes, tried it with "none" set for the Projection Template but it still gave the error message.
    However, I just installed DS4.9.2.70 and tried again. Result; immediate success! The clothing object is quickly converted to a conforming clothing figure.
    Thanks for the help.
