Little white dots
ghastlycomicghastlycomic Posts: 2,531
I'm building a vegetation shader and there's these little light dots that show up in the render right where the highlights are. I can get rid of them by making the surface matte finish but I want it to have a bit of a sheen to it.
What value should I be looking at tweaking to get rid of these dots?
    Specular/glossy and basic lighting model (Plastic/metallic/skin/etc...)
    Does this shader use displacement to add '3d-ness' to the vegetation?
  • ghastlycomicghastlycomic Posts: 2,531
    Yes, there's a slight displacement added.
    Hmmm... it seems to be showing up on other surfaces too that have displacement even with matte surfaces.
    1280 x 752 - 473K
    Deep Shadow Map renders the artifacts as orange squares.
  • SzarkSzark Posts: 10,634
    edited October 2012
    Yes this is a known issue with mapped shadows. Either move the cam a touch and rerender or use Ray Traced Shadows to fix.
    The graininess maybe coming form the Advanced Render Settings Shading Rate being to low a quality. 0.20 is a good place to start. Depending on light and surfaces I sometimes have to increase the quality it to 0.10
    Post edited by Szark on
