Hat Deformers from Netherworks
Hi:
Has anyone out there tried to use the Hat Deformer from Netherworks? I am trying to attach some magnets to the Anders hair (this is a pp2 file, not a cr2), and I cannot get the magnets or the collective attachment file to attach to the hair. I am following the instruction included in the Readme that came with the download; I have tried to load the magnets, then apply attachment. Then I tried to parent the magnets clusters themselves directly to the hair. In both cases, I used the y-trans file to raise the magnet field clusters to the hair, yet the hair did not reflect any indication that the magnets were applied or, when I adjusted the magnets, that the magnets were having any effect. What am I doing wrong? Any advice will be greatly appreciated. Thanks!
Did you make sure the DForms were affecting the hair? Select the hair, then in the DForm pane click Add Node(s) and in the dialogue that opens seelct all of the DForms for the hair tool. Do note that DForms work on the zero state of the mesh, so if the fiugre is posed the fields may not work unless offset to counter that.
Thank you, Richard. It worked perfectly. Thanks again!
