Cloth on Quinn for G2F
Does anybody know what cloth are used in the promos for Quinn for G2F. I'm looking for the top from the main promo and the lace blouse where only the collar is shown. Thanks!
  • SaiyanessSaiyaness Posts: 715
    Total fluke that I saw this post :p
    I thought I put it in the products used! I do apologise.
    The top in the main promo is from this set http://www.daz3d.com/ultimate-pattern-design-kit (Dynamic cloth)
    The dress (with the collar) is from this set (that I thought I added to that list) http://www.daz3d.com/high-garden-outfit-for-genesis-2-female-s
    Both are using shaders from this set http://www.daz3d.com/pd-iray-shader-kit-1 ;
    -Saiyaness
  • Rod Wise DriggoRod Wise Driggo Posts: 2,313
    edited May 2016
    Thanks Saiyaness, already own the pattern design kit (memorized that as shaders ;-) and the shader kit, so hopefully I can rebuild that top - once it has the necessary material zones at least. The garden outfit I might wishlist. From the promos I would have never ever guessed it that you've used that one.
    Update: Draping the dynamic cloth and applying the shaders from Parrotdolphin works fine. Only problem I'm facing are the seams/skitches. There is a dedicated surface for it but whatever shader I try to apply the seams/skitches are never visible. Any ideas?
    Post edited by Rod Wise Driggo on
    edited May 2016
    I am totally stumped on how I got that edge seam O_O I had a false memory of there being a material zone for it :p I've tried heaps of settings with the PD shaders to see if that was doing it but to no avail O_o
    I'll boot up the ol' laptop (where the scene file is) and get back to you. Weird!!
    EDIT: Okay, laptop battery is dead. :p I got a new computer about a month ago so poor old laptop is neglected :p I'll charge it overnight and get back to you in the morning. It's 1:22am XD If you figure it out, yay!!
    Post edited by Saiyaness on
    Thanks Saiyaness, looking forward to any info. I played around with the stiches surface but without any result. Also tried the supplied materials without luck.
    edited May 2016
    Sorry for the late reply O_o
    Okay, just did some playing around and the Stitches only worked for me or were selectable on Length02 under Styles and AFTER draping. So weird!
    1000 x 1300 - 426K
    Hi Saiyaness, first of all thanks for taking the time. The stitches work as described on length02 after drapping. Strange behavior indeed but at least it is now working that way. Thanks again!
    You're welcome! I was totally banging my head on the desk over that one. :p I haven't played with Dynamic Cloth much since getting my new PC and it's so much faster draping now. *_* Definitely need to start playing with it again! Thanks for asking the question XD I'll try to remember settings next time :p
