Delete Packages?
I'm using all the cloud has to offer. Should I delete packages? see attached. And.... so that I dont have duplicate installations (I know there are quite a few) should I uninstall content?
  • namffuaknamffuak Posts: 4,514
    If you're happy - fire up DIM, click on the magnifying glass by the filter box - then 'filter by tag' -> 'content' -> 'connect installed'. This will list all the packages that have been installed by Connect (some may show in DIM's 'ready to install' tab). Then select them all, uninstall, and delete the packages. Finally, go to 'ready to download', select them all again, and right-click 'hide all selected'.
    Poof! Clean, gone, and they won't show up again.
  • MarshianMarshian Posts: 1,465
    That was pretty easy. I'm so relieved after that huge digital movement, know what I'm sayin'?
    Thanks namffuak!
  • twitch99twitch99 Posts: 81
    So glad I saw this post, been trying to figure out how to manage DIM versus Connect loaded content for a while.  Thanks namffuak!!
    One question, is there any way in Connect to determine the last time an update to a product was installed?
    Any way to limit Connect installs to DAZ only files and not Poser formats?
    I'm still comparing DIM and Connect to be sure I don't miss product updates.  Every time I run update metadata, Connect seems to "find" products that need to be installed.
    I feel like I spend too much time trying to manage content and not enough time creating.
  • Richard HaseltineRichard Haseltine Posts: 111,456
    Install date is in the Info tab at the bottom of the Smart Content pane
    Is it installing Poser-format files for products that have DS-native versions?
    I will need to double check that, it seems like I have multiple version of the same product in Smart Content that I did not have before Connect, but I have not looked at the file level yet
    Did you have the product installed with DIM or manually also?
    edited July 2016
    I need to revisit this and may need to go deeper than before.
    I'd like to:
    • Have all content I've purchased from the store in one place- Cloud Connect seems best.
    • Remove duplicate product installs. However- In runtime/textures/product name I have created custom maps for some products that I'd like to keep but they are too scattered to find them manually.
    • Delete install packages (zips). I dont need these right?
    • I dont need poser files unless there are scene files (a few of DMs products Pz3's) or the main prop lives there and the DS files are only materials.
    I tried to follow namffuaks suggestion again but could not follow his last step- nothing was there to hide.
    Hopefully this is easy...some base level start over kind of stuffs
    Post edited by Marshian on
