Time delay physics?
Kodiak3dKodiak3d Posts: 223
Is there a way to get Physics to not kick in until a certain time in an animation?
  • 3DAGE3DAGE Posts: 3,315
    HI Kodiak3D :)
    not really,.. but you can fake it,
    If the problem is gravity,. you can switch off the default scene gravity, and replace it with a Direction force, (pointing down (default))
    The direction force is more controllable , since it can be key-framed, so, you can switch it on when you need it.
    Hope it helps :)
  • Kodiak3dKodiak3d Posts: 223
    OK, thanks 3Dage, I think that should solve the problem. Much appreciated.
