Problem with light/shadow
in New Users
Hi, the image below:
the light not affect the clothes. when i fix it?
thanks for all.
thanks for all.
It's hard to tell what the light is doing when there's no background. Your headlamp could be on too.
The light's not hitting her right hand either. Where do you have the light positioned? What kind of light is it? Point light?
If you are using a point light you may have to change its size/intensity to get it to reach the whole body.
see it:
Which renderer?
Go to the outfit she is wearing and in the Surfaces tab, select one of the surfaces and look up at the top of the list...which shader is it using?
Daz Studio Default.
the renderer is 3delight, i change the color of light to red, see:
dont affect the clothes :/
Okay...look under Reflection...is there an image map in the Color slot? It looks like the preset for the suit is using reflection maps as opposed to raytraced reflections.
yes, have a image. i must delete it?
Yes, removing it will turn off mapped reflections...and should show the light affecting the clothing. But without an environment (full room/skydome) the suit will look a bit dull.
thanks mjc1016 ^^ i can solve it
Wow, now that is neat! Nice image!
