Classic Denim Jumpsuit for Genesis 3 Female(s) - Question
cosmo71cosmo71 Posts: 3,609
edited May 2016 in The Commons
Classic Denim Jumpsuit for Genesis 3 Female(s) - will this jumpsuit work also for flat feet poses and shoes or just for high heels?
Vendors, please, let us know in your product informations if your pants will work with flat feet poses or not. I for myself don`t need pants just working for high heels or flat feets, pants should have the option for both, high heels and flat feet poses and shoes.
Post edited by cosmo71 on
  • Cris PalominoCris Palomino Posts: 12,591
    Do you have a specific example?  I have many pants models and they work with either.  There isn't a difference in foot postion that should have bearing on the pants that I can think of, so you'll have to explain further.
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,559
    yes they do the foot pose is seperate add choice in it's options for those highs so your character doesn't automaticly go to the high heel pose if you just select the out fit and not the complete wear all including shoes also there's a few different morp options can see in the paramatars tab
    1343 x 1343 - 4M
  • cosmo71cosmo71 Posts: 3,609
    Here is an example, these pants work just with High Heels, if you use flat feet poses and shoes the heel of the pants poke through the ground and there is no adjustment morphs to correct the feet / heel of these pants (back length for example)
    Farrah Outfit for Genesis 3 Female(s)
    okay, thank you for the answer
    Ah, yes, I can see what you mean, Cosmo.
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Easy fix, add a deformer to each leg and rotate it till the angle is straight or move the back part up to match the front part. Done it several times, works pretty well.
    But it would make things much easier if pants have the adjustment morphs included, like (adjustment for lenght (back - front - both - lower legs/feet) , back up/down for the heel or feet in general, widen morphs for the feet section of pants). Pants in general need more adjustment morphs for the feet section to make it easier to use different shoes, boots.
