i need help for morph use with DS 4.9
Hellow, I'm DS 4.9 new user in Japan.
I have trouble about morph. I need help.
I have contents wrote below.
*Teen Josie 6 (Josie pro bundle)
*Expressions for teen Josie (also Josie pro bundle)
*Genesis 2 Female Head Morphs
I checked these are installed by Install Manager.
Josie figure appers in DS Contents Library TAB, and it can be loaded.
It seems OK, no problem.
But I cannot find Head Morphs nor Expressions control.
I checked DS Parameter TAB with select figure head.
But I can't find morph parameters.
I checked Contents Library TAB with product name 'E' xpression...
But I can't find it.
I checked error in DS log.
But No error wrote.
How can I make Josie 6 laughing face or crying face ?
Can somebody help me ?
The head morphs can be found either in the Parameter pane or Shape pane. Expressions can be found int the Parameter pane once the Head node is selected under Pose Controlls. If a morphs package ahs the following line, "there are no user-facing files", in the Notes selection of its store page it means they are just morph dails added to figure.
Thank you for reply.
I understood that the morph package is invisible.
then I checked Parameter pane and Shape pane again and again.
I can find charactor morpf 'Josie', it is only 1 morph I can find...
I have Poser10, so I tried loading Josie6 into Poser through DSON importer.
Head morpf and Expressions loaded into Poser, I can make Josie6 laughing face with Poser.
It seems OK.
I installed DAZ Contents using Install Manager.
but I installed the contents into another folder different from initial default contents folder.
All contents installed into the another folder.
It was wrong ?
Hellow.
I got the solution.
I did uninstall all contents.
Then I did re-install all contents into initial default folder by Install Manager.
It comes good.
Expressions and morphs appears in Parameter pane when Josie loaded with Daz Studio.
Installing contents into anather folder.. it is wrong, I think.
Thanks.
