pile of leaves
srieschsriesch Posts: 4,243
edited May 2016 in The Commons
Are there any piles of fall-colored leaves available?
I have individual leaves, blowing leaves, flat scatterings of leaves, but can't seem to find any actual piles.
Post edited by sriesch on
  • bmosaltbmosalt Posts: 52
    http://www.daz3d.com/maple-tree-pack-1
    For some reason it isn't listed on the product page, but this one has a leaf pile.
  • Charlie JudgeCharlie Judge Posts: 13,303
    Are you sure? I have the maple tree pack-1 and I don't see any leaf pile as part of it in DS.
    I do, however, have a leaf pile that was part of Lisa's Botanicals - Mighty Oak which is now available on Hivewire
  • srieschsriesch Posts: 4,243
    edited May 2016
    I also found Flinks Autumn Leaves over at Renderosity shortly after posting, I should have checked there prior to posting.
    Actually, you are correct. It's not in the main product, but it's an expansion addon. For some reason it's no longer available in the store.
    http://docs.daz3d.com/doku.php/public/read_me/index/18110/start
    Sorry about that.
    Not quite piles of leaves,  but there is the old RDNA ground cover modualz  http://www.daz3d.com/rdna-groundcovers-vol-1
    Any chance you have a render and/or a wireframe screenshot of this product?  Although my leaf pile need has now been met, I've been staring at the promo for this RDNA ground cover product for a while trying to decide exactly what one plant looks like.  I wish the promos were a lot bigger.
  • ghastlycomicghastlycomic Posts: 2,531
    You could always make a whole bunch of trees in Bryce and export them, then delete their trunks (which are useless anyway) then just overlap all the leaves until you've got enough density. Gonna be pretty polygon intensive though.
  • HavosHavos Posts: 5,601
    edited May 2016
    There is not much geometry in this product. Each leaf pile is a slightly concave plane, and then transparency is used to form the leaves. Below is a render of one of the sets of piles place over a white floor.
    EDIT: Attached a wireframe image
    1920 x 1080 - 2M
    1920 x 1040 - 300K
    Post edited by Havos on
    Thanks for the info!
    I added a wireframe image to my original post
