PyCloid 0.2 beta available
The new release is available at http://www.f1oat.org/pycloid/index.html.
Many new features :
- particles collision with scene objects
- tube geometry along particle path
- fluid simulation
- isosurface geometry
- new sample files
- multi-core CPU support
Hope some CG artists will post very soon nice films done with PyCloid !
Frederic.
http://www.youtube.com/watch?v=tnNDJU8n17o
http://www.youtube.com/watch?v=8k6iVZlJLnM
  • BrianP21361BrianP21361 Posts: 815
    Frederic,
    Any chance you'll be creating a Mac version. I'd buy it in a minute!
  • bighbigh Posts: 8,147
    thank you !
  • HeadwaxHeadwax Posts: 10,421
    yes thank you from me too :)
  • McGuiverMcGuiver Posts: 219
    Fredrick,
    I have done some experimenting with your beta fluids. The fluid simulation works great, but had some trouble figuring out what what settings did what.
    In the Isosurface tab, I found a radius adjustment, and in the fluid tab there is also a radius adjustment. In the radius adjustments, if I choose a setting much over 0.017 the particles disappear.
    I did find that adjusting the viscosity all the way to 10.0 made the fluid smooth out much better. (lower viscosity = lumpier)
    My render really doesn't do justice to how good the water flow can look, but be assured, it works very well when animated !
    I also found that the simulation does not reset to zero time when hitting the rewind button. To reset the simulation, rewind to 1-second, then to zero, or your animation render will show the last frame before starting the animation at frame zero.
    (hope that made sense).
    I need more time to play with it. ;-)
    800 x 600 - 32K
  • h1n0k4m1h1n0k4m1 Posts: 0
    NICE!!!
    Thanks a lot :D
  • 3drendero3drendero Posts: 2,029
    Thanks again to f1oat for upgrading Carrara. Daz should hire you...
    McGuiver, can you post a youtube clip of your fluid sim?
  • booksbydavidbooksbydavid Posts: 429
    Thanks, Frederic! Can't wait to play.:-)
  • edited December 1969
    Yes, there are many things to tune in the code, but as the pressure from users was high, I decided to release it !
    The "Radius" parameter in "IsoSurface" tab applies only to rendering.
    The one in "Fluid" tab is for fluid calculation only (SPH algorithm)
    Both values should be similar, but I keep two different sliders to experiment.
    IsoSurface applies to all PyCloid particles simulation, including those without fluid behavior.
    Yes, there is something to fix for rewind function.
    I have to update the PyCloid website with some docs about fluid.
    What is difficult is to achieve stable behavior, with no "explosion". That is managed by tuning all the parameters, including gravity, but I do not yet have a magic worflow for that ! Let's experiment and share results.
    Frederic.
    McGuiver said:
    Fredrick,
    edited October 2012
    Post edited by 3drendero on
    Unfortunately, I can't seem to get a YouTube account working....just keeps kicking me out ????
    Here's the settings I used for water. :)
    651 x 637 - 163K
    edited October 2012
    Thank you for the screenshot.
    Can you try Vimeo instead?
    http://vimeo.com/
    Supposed to be easy to use...
    edited October 2012
    Attempting to imbed a video of second water test.
    Edit: Well....that didn't work, I'll try the url.
    https://vimeo.com/52197357
    Post edited by McGuiver on
    Please mac version... please...
  • Milo_471560Milo_471560 Posts: 511
    Thats very cool!
    edited October 2012
    McGuiver, crossposted on youtube for for, hope it's ok, otherwise I will remove the it:
    http://youtu.be/I2cpW-B04kc
    Though I have no idea what tags to use to get the video embedded in the forum.
  • scottidog2scottidog2 Posts: 319
    Mac version Please.
  • thoromyrthoromyr Posts: 452
    We can hope! It looks very cool and is certainly a product I will support.
    Any new Pycloid animations out there?
  • BurnartBurnart Posts: 0
    Good on you Frederic - thanks! :lol:
    Does anyone have any suggestions on how to create a flame effect like this with Pycloid and Carrara?
    http://cg.tutsplus.com/tutorials/autodesk-maya/how-to-create-an-awesome-fire-effect-using-maya-fluids/
  • DartanbeckDartanbeck Posts: 21,967
    This is amazing. I can hardly wait to test it out.
    Would it be okay to offer freebie CAR scenes that require (but do not come with) PyCloid?
    I'll read the license before doing anything like that anyways! ;)
    Thanks for this, will be donating soon.
    Yes, you can publish freebie scenes using PyCloid.
    I will be very happy to see artistic works using it.
    Some activities around this plugin should motivate me to continue the development !
    Frederic.
    Frederic.
    Does it work with Carrara on OS X yet?
    Frederic.
    I don't know why I haven't been playing with this yet. Totally swamp at the moment... but I think this even works in swamps! So I'll see if I can get testing by the end of the week. Looks really cool and I love McGuyver's work on it.
    Everyone wants fluids in Carrara - this makes it (and much more) happen!
  • RendernowRendernow Posts: 8
    edited August 2013
    This is definitely worth playing around with. Thanks for your development Frederic. I need to check this out more for sure. It seems like it has many possibilties indeed.
    Post edited by Rendernow on
    I have now made a Playlist of all of Frederic's Demo Videos for PyCloid to help show off it's amazing abilities with a single link. Frederic, if you would prefer I didn't have this playlist and made one of your own, please just let me know :)
  • VenerisVeneris Posts: 115
    Can I create a simulation of water in Carrara and import in DAZ Studio it work?
  • DUDUDUDU Posts: 1,945
    I don't use DS, but I don't think so...
    Particles and realistic ocean are internal into Carrara.
    The best thing to do is to import all your DS scene into Carrara (and I think you'll never back to DS after that ! wink).
  • 3DAGE3DAGE Posts: 3,311
    Veneris
    Wrong direction,.
    Load your DS Screne into Carrara,. or load the figures from the carrara browser and create your scene in Carrara., rather than Daz3D Studio
    Then you can use all of Carrara's features and plugins.
  • RealtimeRealtime Posts: 95
    Mac version please:)
