Nvida Iray Renders
XfitzXfitz Posts: 96
I have been away from lDAZ for about a year and recently downlaods DAZ 4.9 with Nvida Iray. I must be doing something wrong because: When I light a scene the Iray render does not respond to the my lighting set up. l will attach two files to illustrate this - both rendered with the same single spot light. The 3Delight render responds how I am used to seeing with DAZ renders but the Iray render does not. Can someone explain to me what is going on?
    What are the settings on the light?
  • Richard HaseltineRichard Haseltine Posts: 108,889
    By derfault Iray will be using the Ruins HDRI to lght the scene - you need to go to the Environment group in render Settings, on the editor tab, and set Environment Mode to Scene Only - and then you will probably want to adjust the Tone Mapping settings. You will also probably want to adjust the light - set it to Photometric mode and use the Luminance value to adjust brightness - though with just one light, especially in the absence of geometry to bounce light around, you are gonmg to have trouble avoiding noise.
  • XfitzXfitz Posts: 96
    Thanks.. You have given me a place to begin. Can you recommend a good tutorial source where I can plow thru the new settings that have appeared since I last used Daz -  I feel like Rip Van Winkle, waking up to a new DAZ3D world
    https://www.youtube.com/user/SickleYield/videos for video tutorials, http://sicklyield.deviantart.com/journal/ for text tutorials.
    Thanks. Very helpful..
    You're welcome.
  • 3delinquent3delinquent Posts: 355
    Go to the main page of the forums. In software Daz studio discussion there is a locked thread near the top of the page called iray start here. It has heaps of information you might be looking for.
  • marblemarble Posts: 7,500
    edited May 2016
    I'm pretty new to IRay as a serious option. Until about two weeks ago I had only tinkered with it and had used Reality/Luxrender or 3Delight by preference. Since I've had the new PC I have dived into IRay full time and I must say that the new DAZ videos are a good starting point, as are the Sickleyield tutorials.
    Look on Youtube for the DAZ Channel: https://www.youtube.com/user/WWWDAZ3DCOM/videos?shelf_id=4&view=0&sort=dd
    Post edited by marble on
