Why no love for the super-hero?
13»
  • FSMCDesignsFSMCDesigns Posts: 12,846
    The Ultra Bodysuit is OK but with males it has some weird issues in the right upper arm area - in certain poses, chunks of it just vanish. Poke-Away is useless here because to get the suit to fit right, the arm below has to become very thin, which isn't acceptable with short sleeves. You can bet the left arm all day lomng and it doesn't hurt anything - just the right arm in certain positions.
    Apply a smoothing modfier (edit - figure - geometry) and it should fix the sleeve issue.
  • The Ultra Bodysuit is OK but with males it has some weird issues in the right upper arm area - in certain poses, chunks of it just vanish. Poke-Away is useless here because to get the suit to fit right, the arm below has to become very thin, which isn't acceptable with short sleeves. You can bet the left arm all day lomng and it doesn't hurt anything - just the right arm in certain positions.
    Doesn't do anything at all. Then when I pose the figure and try to do it, it tells me it can't do that operation. Applying multiple smoothing iterations almost fixes that particular problem but creates many many others.
    So then I got the idea of selecting the Ultra Body Suit, doing 'Edit - Object -- Geometry -- Apply Smoothing modifier'. Now it works perfectly.
    Interesting.
  • As an answer, it seems that most folks doing superhero costumes don't submit them here, as some were just advertised on the other site.
  • RKane_1RKane_1 Posts: 3,039
    edited April 2017
    There is PLENTY of good content out there, yes.
    But I also love to see improvements as well. The more realistic, the better though I LOVE the Captain Charisma set. Bought it RIGHT off. :)
    Post edited by RKane_1 on
  • ValandarValandar Posts: 1,417
    Mostly because most superhero stuff is copyrighted. With a basic bodysuit and cowl, there's not much farther you can go - specific things like ear wings, belts, and so on tend to be from specific characters.
    Ear wings could be for a viking helmet or Hawkman's Helmet. Seems generic enough.
