Failed to Save Morph
When I go to save as morph assets, all the sudden now I'm getting an error thats saying "Failed to save as morph Asset(s) See Log file for details.
I check it and this is what it says.
WARNING: fileoutput\dzassetoutfile.cpp(640): File could not be opened.
WARNING: dzmorphsupportassetfilter.cpp(664): Failed to write Morph Asset(s).
Failed to save Morph Asset(s). See the log for more details.
  • Richard HaseltineRichard Haseltine Posts: 108,506
    Is you copy of Daz Studio still showing as Daz Studio Pro?
  • deleted userdeleted user Posts: 1,204
    yes
    edited May 2016
    I did reinstall Daz 4.8 today would that have anything to do with it? - not a downgrade from 4.9. I am still on 4.8
    Post edited by deleted user on
    Check Help>About Installed Plug-ins - are any disabled?
    No their all green.
    Drat, I was hoping for an easy answer. Clutching at straws, but please post a screen shot of the option dialogue as you try to export your morph.
    I've seen that error when the folder I was trying to save to was not writeable...
    Where are you trying to save the morph to?  (full path)
    Funny, now all the sudden it's working again. I'll get a screen shot if it pops back up. I don't get it because it's the same scene. I never closed daz, fearing the morphs would be lost... I guess sleeping on it fixed the issue? lol.. I have no idea. But I'll for sure print screen if/when I see it again.
    Are you saving to an external/USB/Network drive?
    It could be that it WAS going to an unwriteable folder.
    No it's going to the right folder...
    I don't know how to change the morphs directory even if I tried.
    I can try to change the Vendor name, but the directory is not editable
    Ok, it looks like it's only doing that to one particular morph. Weird...
    That is weird...
    You can set the base content directory used at the top of the options dialogue, the other names then dertermine where in that directory's data folder the morph is saved.
  • I have this exact same issue except mine is NOT self correcting. I've had it for some time now. Haven't been able to save custom morps for months
    686 x 882 - 128K
    696 x 759 - 98K
    What are the options you are setting when saving?
    I'm ERC freezing upon loading the morph in successfully. Then adjusting rigging to shape. Then File/save as/support asset/morph asset/morphs/morph loader/gen9/then the name of my morph. I don't see any other options and this use to work flawlessly before the error starting popping up.
    You should get options for author and product name, and 9as mentioned earlier in the thread) a selector for the content directory to use. A screen shot of the options dialogue would help.
  • dcardone1986dcardone1986 Posts: 18
    edited March 2024
    well....after closing Daz and opening later. I tried agian and it worked. real head scratcher
