Star Trek Builders Thread!
Adding to Cart…
Yay found you at last .....with a little help :).....Thanks mdbruffy....
naw it all boils down to gold pressed latinium
Yeah, but not even the most lavish Ferengi can wipe with gold pressed latinium!
At least not bricks like you pictured. I suppose some sort of foil may work.
Hmmm...
Hmmm...
Scratchy! :grrr:
You've heard of conspicuous consumption? You can have the other side of the "coin".
The purest Latinum wrapped in a safe, but micro-thin foil (of worthless, but ultimately protective gold). Relatively safe on plumbing.
For the well-to-do Feringi who just doesn't give a s***.
And that's it! 26 posts! No longer a "New Member". Hahah, but don't think you're rid of me yet. Unless you are, but that would be a coincidence.
You're welcome.
Have to ask :P , How is it going with the Founder and the Jem Ha'dar morphs?
they are pretty much done , work schedule has been a real bear lately so i haven had anything more that a few minuates here and there to do anything .
when i get a few days in a row i will package them up and send it out for testing .
once i recieve confermation they work as advertised they go into the package with the rest of the morphs .
when all the morphs are done , i will put them up on share cg .
that had always been the plan
Surprise, surprise! click on the link and right to the Post! I like that.
Must be nice I haven't gotten a notification for this thread or for three of the other four that I'm subscribed to:coolmad:
Ah-hah! So it's finally up and .... well, crawling!. No double-spacing? Fagh!!
The thread looks kind of bare, so I guess it's a good time to post a pic. I'm still working on the 'season 4' update of the TOS engineering room, and had planned on leaving the 'washer & dryer' units to be taken care of by XCalpPro's freebie, but they were so long that they barely fit into the available space and left almost no room to walk around, so, of course, I had to model those too. ;)
While I was at it, I decided to modify them a tad, as well - I opened up the backs, and made the various cylinders on them into containers that glow with contained energies. I also decided, since this related to "The Time Trap," to incorporate the little alcove where Kali (the Klingon) hides the explosive device - it's that little dark rectangle on the back of the far unit shown here. I also added more definite controls to the already-existing console that before appeared to have half of a plumbing fitting stuck on it, and added a display screen directly above it, so now these units appear to be interactive.
Full-size image: http://ptrope.deviantart.com/art/Washer-Dryer-WIP-303230172
Interesting ;).
(btw, no apostrophe in that first "its" ... ;) )
speaking of latinum and quatloos , is there any interest in this
the quatloo betting token , the only coin of value in triskellion
You bet! :cheese: Those look great.
Only if you can tell me whether a Quatloo is Four Loos, or One Fourth of a Loo.
Gotta stock up on Latinum Loo Paper if it's 4! That's a lotta Loos!
testing to see if forum thread sorting has been fixed, as I suspect it might have
seems i was wrong
New threads appear first, but new posts don't bump threads to the top yet.
ya i saw that with my test
it'll be nice when the reply bots start working all the time instead of just some of it.8-/
To make sure they work, make sure you are LOGGED IN when you view the thread. Once I started checking that (and the Forums do log you out after a period of inactivity), I have not missed a notification.
My latest Seven render large version at DA http://jaguarry3.deviantart.com/#/d51yv9n
To use a term Seven used quite often, "That picture is quite efficient" :)
Here (with much help from GRFK DSGN) are the glowing Romulan tattoos that Bluto wanted.
DOWNLOAD HERE: http://www.sharecg.com/v/62356/view/11/Poser/Glowing-Romulan-Tattoos-for-M4
Sorry DAZ Studio pals, but this is all Material Room majikx and probably will work only in Poser.
Go to the Material room folder to apply these textures.
Marquis member of Voyager
larger version : http://mototsume.deviantart.com/art/USS-Voyager-Marquis-Lt-Crew-Member-305722656?
xo giving the co a quick brief before mission
Image removed by a moderator till resized...please see this thread for info: http://www.daz3d.com/forums/discussion/510_98/
try again
hopefully photo the size it needs to be. briefing room with cpts ready room of on the side
Looks intresting. TOS or NG? I'm asking because your characters are wearing TOS uniforms while the structure looks NG.
definetly looks NG to me - nice work :-)
I've been working on an "undersuit" to go beneath the Cardassian uniform tunic Bluto is working on. I had to improvise a little since I couldn't track down a picture of a Cardassian without his tunic on. How does this look? I made the texture for the M4 Bodysuit, but perhaps I should have just made it as a second skin for M4?
Looks good:)
Here is another render from me
mylochka , i think the bodysuit works wonderfully well with the cardy uniform in mind .
i that note i think in going to have to go back and re work the uniform , no matter what i try , it want to come apart at the seems
so if at first you dont succeed, .......
back to the modeler . post some progress pix soon gang
