Use Genesis 2 textures with M4/V4.
The title pretty much says it all. Is it possible to use Genesis 2 textures with M4/V4?
Not by default.
If you own "V4 for Genesis 2 female" and "M4 for genesis 2 Male" you could use Map Transfer in DS to convert the textures to V4/M4 UVs.
edit: or if you have Blacksmith3D or Texture Transformer there are Male and Female add-ons (available at Renderosity) that enable you to convert textures using G2F/G2M base UVs to V4/M4.
