Scaling a Script Box Down To Fit
So I have the Instant Make Up for V5 (which is super cool by the way) and the box fits into the window on my pc (I have a really big monitor) however, it does not fit into the screen space on my laptop.  The very bottom is hidden and of course, I can't use it without the two buttons on the bottom.  I have tried everything I can think of.  I can make it less wide but I can't make it less tall.  I try right clicking and resize and nope, can't do it. I have tried pushing the box up so the top is slightly hidden, nope, won't do it. I don't know where to go to change the size manually. I do about half my work on my laptop so would really like to be able to use this on my laptop.
  • TaozTaoz Posts: 10,280
    Have you tried to drag the top down instead?
  • Richard HaseltineRichard Haseltine Posts: 108,657
    You can use the tab key to move between buttons, and the space bar to press them when highlighted - one option is to work out how many tabs you need to get to the desired button from the last thing you can select, then press space. Not ideal, but unfortunately the switch to 16:9 instead of 16:10 aspect ratios by cost-cutting manufacturers means there are suddenly a lot of screens only 768 pixels high, which had been a diminishing part of the market and so was not widely suported.
  • IceDragonArtIceDragonArt Posts: 12,870
    makes sense.  the laptop is 5 or 6 years old.  and while it has a largish screen for a laptop that could be the problem.  I will give that a try and see if it works.  Will work it out on the one I can actually see lol.
