How can you identify Iray shader on a figure or prop
5200north
in Art Studio
I want to take full advantage of the iray rendering engine and I know that all the surfaces should that be iray shaders but is there a way to tell if a surface is in the old format I like applying new iray shaders on older props but I think I miss some surfaces occasionally
Click on the item in your Scene Tab then go to your Surfaces Tab select the item. Click on the arrows to expand the selected item. All figures and props with an Iray shader will show the following surface properties:
General
Base
Metallic Flakes
Top Coat
Volume
Emission
Geometry
That Emission channel is the immediate clue that the surface is Iray ready. All of your Iray surfaces should show that option.
You can also just select the surfaces and look at the top of the pane. It will say Iray Default Shader or something similar for Iray, or Daz Studio Default for the regular Daz shader, and whatever other name for whatever other custom shader may be applied.
