GENERAL FREEBIE REQUESTS Part 2
16061636566100
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    There's a set for G2M in the store, I think, with fantasy hair and a goatee...
  • KeryaKerya Posts: 10,943
    Looking for a 3D model of a radiostation with dj booth with mike. have googled and can't find anything. very surprised nothing for a radiostation model is out there. Need for an animated story working on.
    I can't find one for free ... if you google radiostation for poser you will find one for $9.95 at Contentparadise
  • Thanks Kerya so much and at the price is great.
  • demonsworddemonsword Posts: 18
    Is there any chance anyone has made (or could make) a version of the Flash that resembles the one on the CW TV show?
    For a while, I've tried hodgepodging something together that looks close with stuff I've bought and downloaded over the years but I can't really come up with anything that looks ...um... well... good. :P
  • Charlie JudgeCharlie Judge Posts: 13,309
    edited May 2016
  • DollyGirlDollyGirl Posts: 2,702
    edited May 2016
    This one has the wings as well: http://www.sharecg.com/v/73674/gallery/11/Poser/Golden-Age-for-Dazs-M4
    So I read your request a bit closer and the above wings are not what is used by the CW Flash. So I am going to suggest that you go
    here: http://www.sharecg.com/v/29080/gallery/5/3D-Model/Symbols and here: http://www.sharecg.com/v/9915/gallery/5/3D-Model/Profiled-Rings spacebones has a flash symbol in the first package and the second package has a ring. Both are in obj so they will import into DAZ just fine. Once you have them in DAZ you can create a cylindar primative. Position the objects and scale each of the parts until you have the CW Flash emblem. If you export out all three together you will end up with one object that has the three material zones one from each of the original objs. Set up your suit bring in the new object and scale it to your model.
    For the mask I think joequick's Nadino Mask will work for you here: http://www.sharecg.com/v/51122/gallery/11/Poser/M4-Nadino-Mask
    for the boots and gloves I would use joequick's Golden Age package here: http://www.sharecg.com/v/73674/gallery/11/Poser/Golden-Age-for-Dazs-M4
    If I were rendering with iRay I would use parrotdolphin's leather shaders here: http://www.sharecg.com/v/78685/view/7/Material-and-Shader/Pd-Daz-Studio-Soft-Leather-Shaders to enhance the texture of the suit. They are designed for 3Delight but work really well in iRay.
    Post edited by DollyGirl on
  • fleetppfleetpp Posts: 199
    Anybody know where I can find the V-neck sweater and jeans mats for Kirwyn's EZcasual shown at renderosity https://www.renderosity.com/mod/freestuff/v-neck-sweater-and-jeans-or-cutoff-shorts-repaired-download-link-/49010
    The link there doesn't work.
    Very respectfully,
    fleetpp
  • fixmypcmikefixmypcmike Posts: 19,705
    edited May 2016
    Very respectfully,
    fleetpp
    Is it these?  http://www.sharecg.com/v/16573/browse/11/Poser/Textures-for-EZ-Casual-V4-by-Kirwyn
    ETA:  No, sorry, that's not it
    Post edited by fixmypcmike on
    Very respectfully,
    fleetpp
    Thanks for checking; I already have the one from sharecg. I haven't been able to find the ones I want.
    TYVM, DollyGirl. I'm going to get going with that stuff and see if I can get better results in hodgepodging. :)
  • faisanfaisan Posts: 600
    Could some artist create a beanstalk for Poser please? Thanks! :)
    There is one here: http://hivewire3d.com/beanstalk.html Not quite free, but on sale at a low price
    edited May 2016
    The only beanstalk I know of is the one charlie just pointed out. However, if I were wanting a free beanstalk I would go to Dreampaint's site here: http://dreampaint.perso.sfr.fr/poser1.html He has some vines that will wrap around a tree trunk (such as the one on page 2 of Dreampaint's site) or primative to give you the beanstalk look. You will have to scale and position your vines. I would suggest that you open a new scene, add the tree and then bring in the vines and play with position and such. Once you have the beanstalk created I would then just save it out as a prop. The attached image is in Studio with 3Delight. These are Poser props so will render in Poser just fine. I used the tower tree with the staircase turned off and a couple of the branches from the forest sets. On the first page there are also vines called Lianes or the thorny ones called Ronces and these could add more elements. Like the curlycues that you will need to make it look more like a beanstalk.  I used Mapps' flowers from Hamlet of Sir Michael from here: https://web.archive.org/web/20060416045255/http://www.freewebs.com/mapps/downloads6.htm. The ones on the vines are the pink flower. I just pulled the pink texture into Paintshop pro and changed the color to white. The example could use some more tweeking I would add some more curleycues, scale some things to get more randomness.
    303 x 500 - 312K
  • 404nicg404nicg Posts: 270
    Could anyone point me towards a pair of sweatpants for either V4, Genesis, Genesis2Female or Genesis 3 Female?
    And also a pair of khaki pants for the same figures?
    Oh and a visor? Like think fast food worker
    For your Khaki pants I would look through Wilmap's site and see what style you like there is Genesis, G2F and G3F versions. https://www.wilmapsdigitalcreations.co.uk/introduction.php
    For the sweatpants. Optitex has a dynamic pair that fits M4 or Genisis here: http://www.optitex-dynamiccloth.com/FreebieDownload13.php If your female is smaller then M4 you can use the shrink sliders in the Dynamic Cloth window to resize the pants.
    Look in the Genesis section of Wilmap's site. She has one for her golfer set.
    There is a pair of dynamic sweats here...
    They can be draped on any of the females, even though they are originally for M4.
    There are also V4 Cargo pants a couple of pages back.
    Thanks for your quick replies! The dynamic sweatpants are perfect. The plaid textures on Wilmaps golfer set aren't quite what I'm looking for
    What texture are you looking for?
    Try her regular trousers, then, and look for third-party textures (eblank has some, I think) on ShareCG.
  • dakkuuandakkuuan Posts: 305
    anyone know where I can find an outfit like this?  It can be for anything Generation 4 and up.  A3 will work too.  Any thing else from Bleach will be helpful as well, I have the Zangetsu from Sharecg.  Thanks =)
    500 x 790 - 158K
  • ModernWizardModernWizard Posts: 904
    Has anyone seen a free vanity mirror or makeup table or changing table with light bulbs all around it? Looking for something as might be seen in a theater or movie dressing room, a la Cybertenko's awesome [for sale] Old Theater Changing Room: https://www.renderosity.com/mod/bcs/?ViewProduct=103846
    I'm actually just looking for the mirror with the lights all around it. No need for vanities or anything.
    --MW
  • Tramp GraphicsTramp Graphics Posts: 2,422
    You could try these:
    Two items from Hisayan Image Labs (clothes converted to fit Genesis):
    4th down: Kozure_Okami for M3—[converted to fit manually in Hexagon]
    5th down: Yagyu for M4—[fit via Transfer Utility] (Kageto's kimono, obi, and Tabi)
    I typically use the Hakama from the Kozure Okami for M3 and the Kimono, Obi, and sometimes Tabi from the Yagyu for M4. They do require some conversion and adjustments in a modeling program (like Hexagon) to fit Genesis, particularly the Kozure Okami for M3  hakama and Yagyu for M4 kimono, and some custom rigging and weight mapping for the sleaves of the kimono. You'll also need to create your own textures (easily done by modifying the existing ones), but, overall these sets work pretty well.  I use them for my character Kageto all the time, as seen in the image below:
    Unfortunately I tried the items that post mentions Tramp and the clothing are poser dynamic cloth.  This person went to the trouble fit them in Hexagon (which I don't have).  I'm not even sure how I'd begin to do that lol.
    edited May 2016
    --MW
    Why don't you grab a rectangular mirror (lots of those in Rero freestuff) and stick lightbulbs around?
    http://www.planit3d.com/source/meshes_files/household01.html
    Post edited by Kerya on
  • DanGer777DanGer777 Posts: 65
    I was wondering if anyone knows of any links to the Admiral style trousers in Star Wars. The old flare hip. Thanks in advance.
    225 x 225 - 10K
    The only jodhpurs I know of are the M4 Mountie set here: http://www.sharecg.com/v/42635/View/11/Poser/Mountie-Set-for-M4
    Perfect! Thank you so much for the link. You are awesome!
    Anyone seen any free stalls as might be found in a public bathroom / restroom separating the toilets? If I can't find any, I will probably get West Park Ablutions, but wanted to see if I was missing any free equivalents.
    --MW
