Turn off Skin Texture for Genesis 2
NicholasAFilip
in New Users
How do I turn off the skin texture that automatically loads with the Genesis 2 model? I'd like it to look like the standard Genesis model (all gray), or at least have no texturing at all. Basically I'm trying to get it to a point where I'm dealing with solid colors for each part of the body.
Load Genesis...select it in the Scene tab then select 1 surface in the Surface pane. With that surface selected go to File > Save As > Shader Preset. Pick/create a folder in Shader Presets when saving it.
Then to apply, select Genesis 2 in the Scene tab and then ALL the surfaces in the Surface tab. Double click on the preset you saved in Shader Presets.
You're done...or you could go one more step and save a Genesis 2 material preset.
You. Are. Awesome.
Thank you :)
