Anyone have Light Dome Pro?
Its in the Fast Grab and looks interesting. I'm assuming its 3Delight only but I wanted to know if it works in Daz 4.9.  I bought something a while ago that no longer works in the current versions and don't want to spend the money if its not going to work.  (and yes, I know about the return policy but I hadn't gotten around to trying the other before the time ran out. I try and test everything within a week now so I avoid the hassle)
  • KnittingmommyKnittingmommy Posts: 8,191
    I have it, but haven't used it much yet since I got it.  It takes a little bit to figure out.  However, talk to Joe Webb as he swears by it and says he uses it for almost every render.  I'm determined to figure it out and I've added it to my list of products to experiment with in my thread in the near future even though i don't use 3Delight all that often.
    So, I went to fast grab to double check which version was in there and it's gone already.  Was it the Light Dome Pro 2,0 or the -R?  The -R is the newer version.  Did you get it?
  • Pack58Pack58 Posts: 750
    edited April 2016
    I can get it to work in 4.9 (beta) as well as I ever can in 4.7 (3DL, not so much in iRay, probably function if you added a bunch of your own lights, as a skydome at least but I can't see the point)
    Don't have PS on the machine I have D|S on so couldn't check that side of things.
    Edit: Too late. Sorry, got distracted for an hour or so and forgot to refresh the page before posting.
    Post edited by Pack58 on
    I used it a lot in the past. Works fine with 4.9 and it renders nicely to compose layers in Photoshop.
  • kyoto kidkyoto kid Posts: 42,137
    ...was it the original version of LDP/LDP2?  Neither of those work in 4.0 or above.
  • IceDragonArtIceDragonArt Posts: 12,966
    Ya it was gone pretty fast.  Thanks everyone for the replies will keep it on the list as a maybe in the future
  • fixmypcmikefixmypcmike Posts: 19,709
    The original LDP works in DS4, LDP2 does not.
    ...I tried both and alI I end up with is a black viewport.
    Strange, just tried it now in 4.8 and it works (3delight of course).
