ambient occlusion
hello guys!!
usually in 3d software, you can have global illumination, for overall diffuse lighting, and ambient occlusion, for strong "frontier" shadow... Is it impossible in C8???
hello guys!!
sorry, I don't know how to edit!! I mean, of course, Global ill and AO together!
Do you have Carrara Standard or Pro?
If you have Carrara Pro, then in the Render room under the Output tab, there is a sub-category called Multi-Pass near the bottom. Click the Add button and a new window will open with all the different passes you can select. There is an AO pass. You can add as many as you like.
Hope it helps!
