WWII Jeep tread disappearing in Iray.
When I render the WWII Jeep in 3DL, I get this:
But when I render it in Iray, I get this:
What happened to the tires? Where did the tread go, and how can I get it back? Or am I stuck with 3DL for scenes with the Jeep in them?
  • fixmypcmikefixmypcmike Posts: 19,702
    Check the Surfaces pane for how the treads are done -- possibly displacement that isn't being picked up in Iray?
  • PetercatPetercat Posts: 2,321
    It's showing:
    Displacement Strength 50%
    Minimum displacement 0.00
    Maximum Displacement 1.00
    What should I try? I'm not at all experienced with using displacement, but need to learn. Thank you.
    Okay, I set DS to 200% and Max D to 4.00 and things got ugly:
    Might be useful on a monster truck, but not what I was going for...
    1200 x 1000 - 476K
  • Oso3DOso3D Posts: 15,090
    Make sure the Displacement SubD is at least 3.
    3DL displacement goes on a 'per pixel' basis, and adjusts based on the surface very nicely.
    Iray displacement is based on the mesh and pushes based on each vertex. It is incredibly sensitive, thus, to mesh density. Displacement subdivision essentially adds complexity just for the purpose of displacement (I think because it may be less hard on rendering than actual subdivision? Not sure)
    Where do I find the Displacement SubD setting?
  • scorpioscorpio Posts: 8,533
    In the surfaces tab underneath the displacement settings.
    Do you mean surfaces: editor: displacement? All I see are displacement strength, minimum displacement, and maximum displacement.
    Try setting displacement strength to 0 and back to whatever it is? Sometimes when converting it misses subd.
     It should be right after maximum displacement.
  • barbultbarbult Posts: 26,358
    edited April 2016
    Have you converted the surface to Iray Uber shader? That will be necessary to see the SubD Displacement Level. To convert the surface, select the Jeep in the Scene pane. Then go to the Surfaces pane, Editor tab and expand the Jeep WW2 to see all the surfaces that make it up. You will see rubber as one of the surfaces. Select it (or select all of the surfaces, even better). Then go to the Surfaces pane, Presets tab and drill down to Shaders>Iray>Uber and double click on the !Iray Uber Base shader. Now go back to the Surfaces,Editor tab and be sure that only the rubber surfaces is selected. Scroll down through the channels until you come to SubD Displacement Level. There you can change it from 0 to 3, as Will suggested. Don't go too high on that value! it will slow your render down dramatically. Even with the SubD Displacement Level set to 3, the tread is not going to look as nice as the 3Delight render. Displacement in Iray just works differently and not very well.
    The attached file uses Displacement Strength .5, Minimum Displacement 0, Maximum displacement 1.00, SubD Displacement Level 3. It looks poor, but my computer can't take any higher level of SubD for this model.
    1458 x 1233 - 501K
    Post edited by barbult on
    Oh jeez, I had just assumed conversion to Iray for second render. Yeah. What Barbult said.
    edited April 2016
    One thing you might want to consider is converting the displacement map to a normal map. Then delete the displacement map from the rubber surface and insert your converted normal map in to the rubber surface Normal Map channel. It will render much faster, use much less memory and look better in my opinion. It will not be true displacement, though.
    You can get a tool to convert your displacement map to a normal map here.
    1458 x 1233 - 511K
    edited April 2016
    Here is my best attempt. It uses both Displacement and Normal Map. The Displacement gives it some true geometry offset and the Normal Map gives it a better level of detail.
    Normal Map 1.00 (using map converted with Photoshop using Nvidia tool)
    You can experiment with different min/max displacement levels, but be very careful to not increase the subD too high.
    1458 x 1233 - 513K
  • Richard HaseltineRichard Haseltine Posts: 108,591
    You could use the Geometry Editor to select, hide and delete everything but the tyres on one copy of the jeep, hide (or delete) the tyrres on the original, and apply the SubD to only the tyres - that willa llow you to use a higher level as you aren't dividing everything else. But normals, or bump, plus a limited amount of displacement is probably better - it's one of the annoyances of Iray.
    edited April 2016
    No, I hadn't. I just did, though, and got the results you did. But with Dstrength at .50 and MaxD at 2.00, with SubD at 4.0, I got this:
    So I'm getting closer! Thanks, everyone!
    1200 x 1000 - 489K
    Post edited by Petercat on
    Maybe I should just bite the bullet and buy "Warehouse Building with Items"... But I like this Jeep better!
    And now that you all have pointed me in the right direction, I actually like the tire tread better, too.
