Human bee
Good day!
I need asap a sting-belt (as attached) adaptable to Genesis 3 female
Can somebody do that for me and in which condition?
I thank you in advance
All the best
Arnold
  • kaotkblisskaotkbliss Posts: 2,918
    This would actually be a pretty easy thing to make.
    Create a primitive cone by going to edit->create primitive
    scale the x, y, z so that it's to the size you want.
    Select the cone then go to edit->create d-form
    move the dform field so that just the last 2/3 of the stinger is selected
    rotate the dform handle slightly to give the stinger a curve.
    Apply a color or texture to the diffuse channel of the stinger's material tab
    Load a belt that you like
    Position the stinger on the belt where you want
    parent the stinger to the belt.
