Hooded cloak for Genesis
DarthDDarthD Posts: 259
Will the textures that do not list the Genesis version automatically work with the Genesis cloak or do I have to use only the ones that say Genesis Hooded Cloak required?
"The Hooded Cloak for Genesis adds an elegant finishing touch to your fantasy renders. This 3D clothing item is a refit of the classic Hooded Cloak, and takes the same textures so you already have loads of options to choose from in the Platinum Club store. It fits all your Genesis characters and comes with length, swing, billow, flare, and more movement morphs."
Some of the other textures available say this-
"This product requires: V3 Hooded Cloak One
V4 Hooded Cloak"
Will these work with the Genesis Cloak?
  • Richard HaseltineRichard Haseltine Posts: 109,054
    Yes, it's just that those are older products and so there was no Genesis cloak to add to the list.
  • IceEmpressIceEmpress Posts: 639
    What about fan freebie MAT poses for the M4 and V4 versions?
  • fixmypcmikefixmypcmike Posts: 19,707
    Yes, all the hooded cloaks have the same UVmap -- if it works on one it works on all of them.
    No, no, I meant the pz2 etc., not the texture itself. I already knew the UV map was the same.
    Material names are the same so the pz2s will work.
