Adding to Cart…
Nope, though I agree that would be awesome :-D. Particles are a great way to sort of "fake" fluids without requiring the horsepower of a full-on fluid simulation. I've done a little research into fluid sims and it's not impossioble, just tricky
Thank you :)
Thank you for your reply , I am very interested in your effect bundle and plan to purchase it as soon as i get paid . I have a couple more questions. Do you plan on making more shape presets in the future. it looks like you offer some great shapes in this bundle now will you be adding any leave shapes or a Flat pane shape to add fire textures?
My second question is would adding transparency maps in the material on the Emitter itself, then use the "Copy Emitter Material to Particles" option help reduce memory usage for like fire or smoke texture or will it not matter? I know you said there are some basic controls in "Parameters Pane" for the Emitter. are there any collision controls to reduce or increase the amount of collision or bounce? and my last question..lol I see in the controls sections in the PDF that I can reduce or increase the number of particles per seconds which maybe a good way to reduce ram usage. is there a limit on how far we can reduce or increase the particles per minute so to emulate Snow fall or increase it to look more soild and can the particle presets be layered or can I use more than one preset in the same scene to make a cascading waterfall
Thank you for your time in answering my questions
My experience so far:
Here are some images:
After loading the emitter, and setting up the simulation according to the documentation. Note that the default setting of particle life is 1.1, which exeeds the default length of animation of 1 second (30 frames). Either increase the frame rate in the settings, or reduce the particle lifetime.
After the simulator has done its thing, I switch over to the animation tab, and go through the frames to select the one that looks best to me.
A quick preview render shows that the emittor will not render with the particles. Also, the emitter can be deleted, but the particles it created will remain in the animation frame. That comes in very handy if you want to combine effects. Here, I have rendered the stream with different acceleration, so one goes farther than the other.
Trying to delete several of the created groups at the same time made my DS freeze (not the system, btw). Like I said, I haven't tested this in 4.9, so I don't know if this is a 4.8 problem.
It's fine for still pictures; they don't do the utility justice, though. The fun is in bouncing the streams off objects to hit characters in the face and that.
The script took about half an hour faffing about number crunching to pour a bucket of stars over Haiku here, taking up practically no GPU or RAM to do so, so it'll run fine on most machines I expect. I ended up moving her in this particular test render, so there's some star embedding going on with her hair that wasn't there with the original pose.
You can terrorize your cutesy J-pop dancers on stage with star bombs, luzz ball lightning into some lizardman's face, kind of simulate throwing a bucket of water over an unsuspecting sunbather - or better, simulate the effects of close raindrops on the camera lens - it's fairly specific confetti at the moment.
I'd certainly recommend it for animation; stills work only mmmaybe not, not at the moment. It's currently not doing much in still images that other props can't do better, but yeah, you probably weren't buying a fluid physics simulator for static work anyway.
As a feat of scripting, it's pretty awesome, good job. Little hearts, and little stylized psychedelic flowers please.
Awesome info thank you very much. . Is there a collision control or modifier?
No problem
. Adding transparency maps to the emitter would still result in an instance for each particle. I'll have to check this, but I think if you were to select all of the particles post-simulation you could paste a shared material to all of them. That can be pretty slow, though, and you'd lose transparency and color change animations. If you are using Iray, you should be able to get some very good smoke effects using transmission settings (though they are slow to render, they look very nice :-) ).
For collisions, you can set "bounceLoss", which will affect how bouncy the particles are. If you look at some of the existing emitters, you can get a sense of how that works. Try comparing the settings to the water emitters to the default emitters, for example, and you can see the impact of bounceLoss.
You change the number of emits by quite a lot! The default limits are 1 through 500. You can also run the same simulations multiple times to thicken up a particle stream (I tend to prefer several small simulations to one giant one, gives you a chance to review and make sure it looks right).
Thank you so much for sharing your experiences and for the screencaps, BeeMKay! It does work in 4.8, but my "official line" is going to be 4.9 and up. I may have updates that are specific to 4.9 and I don't want to catch anyone off guard :-). I hadn't run into that delete issue, but I think I was deleting them one at a time. I'll see if there's anything on my end that could be done to improve that (will have to experiment first though, it may not be something I can affect). Also, keep in mind you can reuse existing particles pools, so you don't necessarily have to delete and recreate each time (unless you want to combine multiple simulations).
About the particle color, two things to check. The base diffuse color is actually set in the parameters pane under "matStartColor," rather than in the surfaces pane, so give that a shot (same applies to Opacity). Also, after you've made changes to the emitter material, be sure to check "Copy Emitter Material to Particles" in the Animation script.
Yep, you can control which objects are collided with, how many times each particle can collide, and how much gravitational velocity is lost on each collision (to alter the "bounciness :-) ).
Like what they just said.
It's dead easy to set up. The script opens up an options screen, and you just play around with the sliders and tick boxes.
Thank you for the feedback and test render, goose_chase!
Check out the "Optimizing Collisions" section in the guide, you might be able to speed up the simulation considerably :-). Heads and hair end up being some of the more intensive colliders because they have lots of fine details and are made of multiple objects. If you have Decimator, try decimating the figure and hair before running the simulation. I've done this quite a bit and it works great! (Just remember to return to the Base or High LOD before you run your runder, unless you dig the PS1 look
Aha! Yep, that's clever. Or aim for less fussy collision sites in future. tbh half an hour for a complex pathing calculation is pretty good in 3D modeling time.
And I've just seen that the scale slider goes backwards too, so yes, the bucket of water will definitely work next time.
Good job.
The material translated properly after using the "Copy Emitter Material to Particles, though it seems that some shader work better in 4.9 than in 4.8..
I've also now tested this very briefly in 4.9, and the simulation runs a lot faster there than in 4.8.
What I like is that you can delete the emitter and save the created bubbles as subset. The subset will retain the animation, so you can easily run the simulation, and add it into any scene you wish to render later,without having to run the simulation with the entire scene loaded. you just go to the desired frame. You also can move around each particle group, and even each particle can be manipulated in size and position (and even the color, though not the material).
I don't know if it's possible to save a single frame, if you want to safe just a specific position (if there's a way, then that would certainly be great).
Thank you very much for all you help .. I get paid Friday :)
I'd just get mjcasual's free metaball plug-in (it works great, but metas themselves take learning anywhere) and hang a metaball from each particle, then hide the particles themselves. Splat! "Liquids!"
how much gpu load for iray renders does this use ?
and it would be nice to see a little movie clip
show your creativity please
So the particles can be handled and modified after calculation of the physics? I already have MCasual's metaball plugin, but it was very hard to use due the difficulty to "re-enact" a fluid behaviour!
Nice work! This plug in has me very interested. I used to use Blender for particle physics but Blender is such a PIA to use.
Also semi OT, but is that a Daz figure in your avatar? I really like the look.
Just a quick note to say that I picked up the package and it runs well on my old PC. I have a Gateway PC that I got in 2005 and it runs the particle generations at a pretty decent clip. I plan on reading the directions so I know what I'm doing next time.
A couple of comments/questions:
1) Are further expansions planned? I sure hope so. Being able to pick from a library of presets would help make it appealing to casual users.
2) A metaball expansion would be super. I was a big fan of the Poser plug-in, Metaflow (I think?), and there were some delightful effects I could create from it. It was great for fire effects!
3) Is there a way to make a figure a particle emitter? This is something Metaflow could do. I think it would use a geometry shell to generate the particles off of. It could be used for create force fields or to generate a human torch effect.
Thanks!
It'll be interesting to see what folks who are confident with animating make with it. Bouncing stars off of a convenient hat in another test today vastly reduced the calculation time down to below three minutes. It's fast with non-complex surface interactions.
Oh, and yeah, hah. She was a happy accident playing around with Iray plastic shaders trying to recreate the Super Dollfie / Dollmore look.
It's a glossy enamel lamp plastic shader from IG Iray Lights and Shaders - Floor Lamps. I can't remember if I ctrl-clicked it or not to presevre the textures. Probably. Either that, or it's straight plastic re-shading with LIE make up, possibly from the fun candy cane set. It's Keiko again (I bloody love Keiko). There's a recent SSS Iray pack that looks promising too, it allows for different grades of plastic transparency, but I haven't tested it on a figure yet; trees and fruit come out really well, like, wow well.
Attached: look but don't touch: a four thousand dollar custom Dollmore. Not mine. Yet. Euromillions tonight.
Thank you :) Keiko looks like a great model, sadly out of my budget! Wish listed instead.
I am pretty excited about the development of Simtenero's particle simulator. One of my biggest wishes for Daz is to include more features that you can find in other 3D programs and so I'm happy to see it happening and how it'll evolve.
If liquids are next - that would be amazing and I can finally put Blender out to pasture.
This is very exciting stuff indeed. I've been after some physics based goodies for as long as I've been a DS user (a good few years now!). While it's a bit out of my budget for this month, you can bet your last dollar I'll be picking it up come pay day. I can't wait to try it out for myself!
...everytime I see "metaballs" I read it as "meatballs".
...hmmm, bouncing meatballs, might have something there. Have them splash into a lake of marinara sauce surrounded by spaghetti and linguini noodles growing on the shore like reeds wafting in the breeze under a shower of grated Parmigiano Reggiano.
Darn it. Now I want meatballs. I haven't even had breakfast yet...
