Question about M7
I should have bought it yesterday when it was on sale but I didn't find him attractive so bought Gianni 7 and Leo 7 instead and thought I could mix morphs with my own. Question is, can you buy a character for M7 and have any of the morphs work at all? I'm assuming there are custom morphs on these characters, not just spinned dials so will they work on G3M if you don't have M7? Thanks.
  • scorpioscorpio Posts: 8,533
    They should work just give different results.
  • MegonNoelMegonNoel Posts: 377
    If it's like other generations then you should be able to use the morph, but like Scorpio said, it will look different from what you see in the promos. The end result (character) that you see in the promo is basically the custom sculpted morphs and M7 together, so if you buy it and don't have M7 you would still get the custom part, but the final result would look different. You would also get the texture set that comes with the character and, unless it is specifically for M7 (which many are not) then it should work on other G3M characters. The description should say which UV set a figure uses, if it says Base Maps or a figure you already own then you're fine as far as textures go too.
  • Sensual ArtSensual Art Posts: 645
    It might look similar to having the M7 dials (head and body) turned to zero. Typically, for other G3 characters their base character dial is anything between 50-100%.
  • WonderlandWonderland Posts: 7,133
    OK, thanks. But there are different UVmaps for M7 other than G3? How does that work, and can they be converted?
  • fixmypcmikefixmypcmike Posts: 19,692
    You need M7 to use textures that require the M7 UVmap
