Old Forum Archives
Miss BMiss B Posts: 3,071
In case anyone hasn't noticed, the old forums (in read-only format) are available --> http://forumarchive.daz3d.com/index.php
The only thing I noticed that isn't working is the search, so unless you remember where a specific post or thread is, it's going to be a bit difficult to find.
«1
  • Kesha2009Kesha2009 Posts: 108
    And my old bookmarks for it doesn't work :(
  • TSasha SmithTSasha Smith Posts: 27,348
    I know there is no way to read PMs and the Member's forum or other special forums.
  • Testing6790Testing6790 Posts: 1,091
    Oh god no search...
    Oh god no search...
    On the old forum the search required people to sign in first but there is no way to sign in to see the search.
  • MorganRLewisMorganRLewis Posts: 233
    They should, if you change the "forum.daz3d" in them to "forumarchive.daz3d"; mine do.
  • Miss BMiss B Posts: 3,071
    Yes, you have to update your bookmarks as Chaomancer mentioned.
  • TatalorioTatalorio Posts: 33
    Also Images are not working :(
  • fixmypcmikefixmypcmike Posts: 19,705
    Yes, until we can log in we can't see images either.
  • whaggettwhaggett Posts: 5
    What's happening with me is --
    Where the image would appear, there is instead the HTML code which would display the image.
    Are others getting the same?
  • Michael CMichael C Posts: 76
    It looks like typing in a page number to go to in the forum archive alos doesn't work. The only way to get to a page appears to be clicking a number or the next and previous buttons.
  • shaaeliashaaelia Posts: 613
    I'm getting the code for the images as well - kinda sucks for the tutorials that had pics in them, let alone all the other great artwork/images/renders/whatever you wanna call ems that was on the forums.
  • Zev0Zev0 Posts: 7,123
    NO BOOKMARKS WORK!!!!!! I was assured that they would!!!!!!!!!
    edited May 2012
    I found out how. just go to the old forums and copy the viewtopic.php?t=189550 from your bookmark after the http://forumarchive.daz3d.com /. The address has changed from http://forum.daz3d.com to http://forumarchive.daz3d.com
    Post edited by Zev0 on
  • TapiocaTundraTapiocaTundra Posts: 268
    edited May 2012
    I have always used Google with advanced search to search the Daz forums. Far superior to the standard forum search and always I obtain the feedback I require.
    Google still directs me to the old forum addresses, the only hassle is to have to "type" ( we are too used to point n click) the word, archive, directly behind the word, forum, with no space in between, then click the go arrow and " Bobs your Uncle".
    For example, Google this...
    Chohole site:forum.daz3d.com
    you will get 36,100 pages...that is a lot of work Chohole :-)
    Post edited by TapiocaTundra on
  • 3dcheapskate3dcheapskate Posts: 2,728
    The info about the basic URL should definitely be included in the FAQ for the new DAZ 3D Forums:. At present the...
    • What will happen to the old DAZ 3D Forum when the new one is put in place?
    - The Old DAZ 3D Forum will be accessible for read only now that the new forum is in place. You will still be able to see all the forum posts from the old forum.
    ...just doesn't answer the question.
  • RAMWolffRAMWolff Posts: 10,365
    Also in order to see images you have to go through this to them to show as well...
    So you have say this at the bottom of the archived thread:
    So you want to just copy the postimages/origimage_1_864846.jpg and then add http://forumarchive.daz3d.com/ so it looks like this:
    http://forumarchive.daz3d.com/postimages/origimage_1_864846.jpg
    Pain in the butt but from what's been hinted is that we will have logon rights again and so images will once again show inline... I HOPE!
    Hadn't thought about images in the old forums not showing up. Thanks for the heads-up Richard. ;-)
    Your welcome! :-)
  • edited December 1969
    Hello,
    What has happened to all the old forum posts?
    There were so many useful helps, hints and guides that are no longer accessible now that the new forum has gone live. All the previous links are broken and I can no longer access tutorials, descriptions and images I was using for my project.
    Is this issue being addressed, and will we be able to access again the extensive backlog of forum posts that prove so invaluable? Would be a great loss to not have these available any more.
    Also, there used to be a specific forum for Mimic work, that doesn't appear to be included in the new forum. Is there to be a new one specific for this area?
    Many thanks
    Richard
  • KeryaKerya Posts: 10,943
    The inline pictures are gone for the moment - but after the new store and forum work they will work on those.
  • frank0314frank0314 Posts: 14,743
    Once the current issues with the forum and store are worked out they are going to be working on the old forum to allow you to log in and be able to do more things. In the meantime to view the images just replace the "forum.daz3d.com" with forumarchive.daz3d.com
    Actually, to view the images on the old forum you look for the image code,
    you copy just this bit postimages/origimage_1_3406197.jpg
    and then you add it to http://forumarchive.daz3d.com/
    http://forumarchive.daz3d.com/postimages/origimage_1_3406197.jpg
  • boni_m_ab7b32f625boni_m_ab7b32f625 Posts: 113
    Another question on the archives. When will we be able to search it? There are so many things there I am trying to research for a project and I keep getting an error screen.
    The best you can do at this time is do a google search on the forum. They will be working on the archived forum once they get the store and current forum running smoothly.
    But if you do the google search bit remember to put the arcive bit in the serch string, otherwise you will get results from here, or links that won't work
    edited March 2013
    Well, it's three-quarters-of-a-year later now, and can we see the images in the old forum threads yet?
    No. :down:
    The 'Log In' link from the old forum still just gives a 404 error. Being logged in via the DAZ site still doesn't make a jot of difference.
    Does anybody still care... ???
    Post edited by 3dcheapskate on
  • Richard HaseltineRichard Haseltine Posts: 108,795
    You can see ther images by appending the HTML snippet to the http://forumarchive.daz3d.com/ link
  • robkelkrobkelk Posts: 3,259
    No. :down:
    I care - there's a freebie in the old Platinum Club forum that I want to download. (Yes, I was and still am a Platinum Club member.)
    No. :down:
    IS it not in this list
    http://www.daz3d.com/forums/discussion/8880/
    edited March 2013
    chohole said:
    No. :down:
    Nope. It's "Ballroom Queen," Andolaurina's contribution to the 2010 Platinum Club Challenge, and it was available at http://forum.daz3d.com/viewtopic.php?p=2563716#2563716 . The zip file is on Andolaurina's website, but the password isn't...
    Post edited by robkelk on
