Where the heck is Reality 4.2?
nelsonsmith
So I've purchased the reality plug-in and installed it, and I'm on the site about to do some beginner tutorials and I've discovered I can't even find out where the plug-in is. The tutorials on the site are using Daz 4.6 or some earlier ver. and the set up is completely different than the current 4.9.
Post edited by nelsonsmith on
Okay, this might be of help to anyone else having this problem.
If you let the DIM do automatic updates of Daz 3D from a previous version to the latest version. You probably have another Daz folder hiding somewhere on your HD, so when Reality says successfully installed, and you can not find it in your plug-ins, the other instance of Daz is most likely where it will be found. After that it is a simple matter of moving, or copying the Reality folder from that spot and moving it to the Plug-in folder of your most recent instance of Daz3D. After that it should show up under the render tab like it's supposed to.
