The Freak 5 skin problems
Hello there,
I have a couple of issues that I need help the Freak 5.
- I turned on the Normal Maps and Displacement for the veins, but they don't show up in the render. (left image)
- I mistakenly did something but don't know why. The skin in the render is now very bright (top right image)
Thank you!
_KN
  • Richard HaseltineRichard Haseltine Posts: 108,990
    Your images are not showing. Is this 3Delight or Iray, assuming you are using Daz Studio?
  • KNKN Posts: 55
    Hi Richard,
    Here's the image.  I am using Iray.
    Thanks for your help!
    _KN
    761 x 450 - 111K
    Displacement in Iray requires additional levels of SubD (in Parameters>Mesh Resolution, the Render setting) as it isn't applied automatically as it is with 3Delight. Normals should work, but the settings may be getting lost in the conversion from 3delight to Iray or it may simpl be that the lighting is not sufficently directional to show either up. At that scale it's a little hard to determine what is going on.
    For the lightness issue, try resetting the Render Settings to default (there's a button in the Editor or Advanced tab).
  • KNKN Posts: 55
    I will try that. Thanks, Richard.
