John Crow morph files help? [SOLVED]
BeeMKay
John Crow was instabuy for me. Shiver me timbers!
Unfortunately, I seem to run into a problem - I can't locate the actual morph injection file?
This are the files installed. They include all the textures, but under DAZ People it just says that the morphs are included under Poser files, where they don't show up (they usually would show up under "Poses" with an M4 character). Am I overlooking something?
EDIT: Here's a quick testrender of the skin using G2M Garen as body. The hair is Axel hair.
Post edited by BeeMKay on
I presume that you have installed both the Poser Core file and the DS companion file.
Ah... Thanks, that did the trick!
I have not set the file download for Poser in DIM, just DS... normaly, the Poser files show up for downloading with the DAZ files. It seems that this files was tagged "Poser Only".
If the poser files are required, does this mean you can't use Connect to install?
I am informed that "The corrected files, included fixed metadata, is on it's way up and should show for customers in a couple of hours."
The product page said this could be installed with Daz Connect, so I tried it. I saw it install some stuff, but then I couldn't find the product. I tried closing Daz Studio and then re-opening. I tried searching in the Smart Content and the Content Library (although I understand nothing gets installed to the content library through Connect.) So then I went to DIM and installed it that way. There were two files; one for Poser. I installed them both and then I was able to find the product in the Content Library when I searched for John Crow. I tried right clicking and selected show in Smart Content and it displayed one icon. But I wasn't able to figure out where that file and other related files might live in the Smart Content. But at least I can access the product through the Content Library. And I can ask DIm where it installed the files if I need to.
(I keep seeing Chohole's Avatar at the top of my screen and I keep thinking she's going to hit me in the head with her club!)
