Adding to Cart…
Thank you. I'll try that.
Thank you. That's very helpful! I'll check into those. I'll probably go with the Nvidia 970 GTX if my motherboard can handle it.
I'll keep that in mind. Thanks.
Interesting. I'll have to try the rectangle. I had no idea I could change that. Thanks for the suggestion.
Wow! A lot of very useful information. Thanks for sharing. I'm anxious to try your render suggestions. I had no idea that I could render to a transparent background. I'm used to rendering on a colored background with alpha channels in Poser, which I always remove during postwork.
I had no idea. I've been using Photoreal. I'll try that. Thanks.
Wow! Fabulous renders! Thanks for the information! A speed increase of 7x or better sounds like a dream come true. I'll definitely check into that video card. I'm not sure which kind of cores my card has. The card came with my HP computer, which I bought about a year ago. It has never seemed to have much power. It's defintely time for an upgrade.
I will try your suggestions. Thank you! I love your renders! Thank for experimenting with the render times. That video card sounds awesome.
I agree--much practice is needed. I feel totally lost in Daz Studio. Yes, he's a gamer and thinks in gaming terms. That sounds promising about the video cards. Thanks for the information.
I'm really confused about the lights in Daz Studio. I'll experiment with the HDR lights and see what happens. Thanks for the tip.
I have no idea how to do that. It sounds interesting though. :-)
The link in my sig for the HDRI list has several 'studio' hdrs...these are set up to mimic photostudio lighting, but are hdr images that get plugged into the environment slot, like any other hdr image.
Just to add something very quickly here: specular and glossy materials -- and reflections thereof -- will dramatically increase render times. That is, of course, the price of good looking PB shaders and orders-lower scene tweaking time.
There is an architectural and caustic sampler available in photoreal mode, as well as the interactive mode when rendering under Iray. However, the results for either option were not satisfactory for me but you may get some mileage out of them.
My card could be grabbed off ebay for about $130 if you look around (maybe less if you are lucky.) It is ok for Daz, but the 2gb memory is very limiting. So you'd be better off getting a new 4gb 960 for just ~$70 more (which would have an added benefit of a 3 year warranty by being new.) I have been able to render images of a single figure as big as 5000 x 2000 pixels with simple hdri backgrounds and lighting in anywhere from 30 minutes to 2 hours. A close up of a face will take much longer. Adding a 3d background also effects it greatly, I can't render a very large 3d background. I think the background that came with the Daz dancer tutorial took me more than an hour at 2000 x 2000. So I usually stick to HDRIs as much as possible, with perhaps a just a few props. I'm still experimenting with the program myself.
