Daz 4.5 ANIMATE 2 CONSTRAINT ISSUE
Hello, I've had an issue with daz 4.5. It seems I can't save parent constraints
in the .duf format. In other words I create the constraint it works fine I save the file,
but when I re-open it the constraint is gone. I have searched the forum but have found nothing
on the subject. Has anyone else had similar issues?
Thanks
Post edited by JD3D on
You are correct. None of the constraints are saving to duf. A fix is in the works.
Will the fix be in a new release of daz 4.5. or will it be a patch?
I could be wrong, but I assume it will be an update to the AniMate plugins .dll
