Unicorns!
2»
  • lx_2807502lx_2807502 Posts: 2,996
    The Unicorns (All New and Awesome!) are back on sale today for anyone that missed out.
    Not sure why it keeps saying "over 70 items" when there are exactly 70.
  • DkgooseDkgoose Posts: 1,451
    Seen that re-adding them all to cart, does the unicorn youth include the unicorn? The page says its included but it's not in the included section part of the product?
  • ArtiniArtini Posts: 10,368
    edited April 2016
    I were also not so sure about what unicorn youth contains,
    but I took a chance, and indeed I got unicorn (adult) as well with my order.
    Oops. It looks like they have fixed the bundle issue with the unicorn youth,
    and now it does not contain unicorn any longer.
    Post edited by Artini on
  • KharmaKharma Posts: 3,214
    edited April 2016
    The unicorns do not install properly with DIM..the path mine installed to is My Library/My Library/Littlefox/Unicorn/AliBea/AB Baby Unicorn/ABUnicornBaby Full etc then I get several errors when trying to use some of the mats saying it can't find runtime/texture/...
    Did anyone else find they end up with 2 My library folders nested and has this been reported? Actually the whole install is a mess will there be an update to fix this?
    Edit to add the Unicorn baby installs correctly to My library/Unicorn/Bits mats
    My library/Unicorn/Poses
    My library/Unicorn/White Mats
    Post edited by Kharma on
  • SpitSpit Posts: 2,342
    CypherFOX said:
    Greetings,
    <rant>
    So...I'm just going to say this.  One of the reasons I didn't shop at RuntimeDNA very much is this kind of crud.  Not the unicorn, it's *gorgeous*, but stuff like...three different winter cloaks for the unicorn, three different spring cloaks, dozens of bits-and-bobs, none of them clearly defined as what's needed for what.
    On RDNA sometimes there'd be a top and bottom, as separate pieces, and then seperate versions for each of three different characters.  Hell, once there was a bottom, a shirt, and a baseball cap, and they turned it into 9+ different products, IIRC.  It's kinda nuts. :(
    I'd rather not see that in this store.  I can't really buy into the Unicorn, because I have no idea what all I'd need to make a decent render with it; it's too damn confusing.  Why isn't FURious Tigers a single item with morphs for each of the items?  Same for the shackles, the cloaks, etc...  I don't get why morphs won't work here; is this something that I've been spoiled on by Genesis' massive compatibility between related characters?
    I end up walking away, unfortunately.
    </rant>
    Lovely, if a bit ethereal, unicorn though...  I hope it works out well, just...maybe not for the folks who break stuff up that should be kept together. :(
    --  Morgan
    Morgan, I think these refer to 'Real Deals'. Kinda like Platinum Club without the Club. So you might get a top in separate products for various people so you could pick for the figure you wanted instead of paying more for a bunch you wouldn't use. etc.
  • SimonJMSimonJM Posts: 6,072
    Yes, I have reported it
    Oh good, I hope they get it updated fairly soon thanks SimonJM
