'Bright' intersection
Hi all.
I have this issue using AOA Advanced Ambient Light and some clothing objects (not all).
It happens with bare skin, too.
The picture explains better than my words:
Since often it is impossible to avoid totally the intersection between objects, is there a way to avoid at least that annoying effect?
Note that it doesn't happen with the shoes, which intersect the floor much more deeply than the jeans.
Post edited by Chohole on
Try increasing the shadow bias, it should help.
There's no 'shadow bias' in the AOA Light. Do you mean 'AO Bias'?
I believe AO Bias is the equivalent for AoA Ambient Lights.
Excerpt:
Source: http://www.ageofarmour.com/3d/tutorials/AoA_advanced_ambient_light_help.html
It was the Bias. I have to reduce it, not increase, but you put me in the right direction. Thanks. :)
Unfortunately, reducing the Bias too much creates artifacts with stockings in other pictures, so I have to find a compromise. Can't eliminate everything. :(
