problem with saving light setup
KN
Hi there,
I saved my light setup as a preset. When I brought the light preset into a new scene, its location is on the ground and diffferent from the original settings (e.g. eye level of the character).
Any idea how i can have the exact setting?
Thank you very much!
_KN
What kind of lights?
It's a group of 3 lights (Accent Light. Side light 01 and side light 02). I have them on eye level and around the head of my character.
I want to use the same settings for another character. But when I brought in that light preset into a new scene, all the ligths are located on the ground level.
Thanks.
What are the lights...point, spot, distant, etc?
I always save them out as a scene subset. and save the render settings (which includes the hdri) seperately .... with that I have no problems with them coming in at the wrong spot/level.
@ mjc1016: The 3 lights are all Spot lights
@Lyoness: ok, so I saved a new scene preset with my lights. How do I import it in to the scene that contains my character?
You said you saved the render settings (with hdri). How do you do that?
Thanks for your help!
_KN
Save as scene subset allows you to just click on it. As a scene, you will need to right click and select Merge otherwise it will overwrite your current scene.
File > Save As > Render Settings Preset...and the box shoul pop up with rhe renderer preselected and allow you to expand that and select/deselect specific options.
Spots and points both should save with 'height' info...distant lights, height doesn't matter.
Awesome, it's working. That's what I needed.
Thanks!
_KN
