problem with saving light setup
Hi there,
I saved my light setup as a preset.  When I brought the light preset into a new scene, its location is on the ground and diffferent from the original settings (e.g. eye level of the character).
Any idea how i can have the exact setting?
Thank you very much!
_KN
    What kind of lights?
  • KNKN Posts: 55
    It's a group of 3 lights (Accent Light. Side light 01 and side light 02).  I have them on eye level and around the head of my character.
    I want to use the same settings for another character.  But when I brought in that light preset into a new scene, all the ligths are located on the ground level.
    Thanks.
    What are the lights...point, spot, distant, etc?
  • LyonessLyoness Posts: 1,632
    I always save them out as a scene subset.  and save the render settings (which includes the hdri) seperately .... with that I have no problems with them coming in at the wrong spot/level.
  • KNKN Posts: 55
    @ mjc1016: The 3 lights are all Spot lights
    @Lyoness: ok, so I saved a new scene preset with my lights.  How do I import it in to the scene that contains my character?
    You said you saved the render settings (with hdri).  How do you do that?
    Thanks for your help!
    _KN
    edited April 2016
    Save as scene subset allows you to just click on it.  As a scene, you will need to right click and select Merge otherwise it will overwrite your current scene.
    File > Save As > Render Settings Preset...and the box shoul pop up with rhe renderer preselected and allow you to expand that and select/deselect specific options.
    Spots and points both should save with 'height' info...distant lights, height doesn't matter.
    Post edited by mjc1016 on
  • KNKN Posts: 55
    Awesome, it's working.  That's what I needed.
    Thanks!
    _KN
    smiley  yay!  I'm glad you got it to work!!
