Mixed textures
I'm playing with terrains. Is there a way to mix textures togther somewhat randomly ?
It's just that a terrain with one single tiled texture doesn't look that good. And the repeating texture always look banded and unrealistic.
So I am after a way to mix mulitple textures on the terrain.
Many thanks.
    edited March 2016
    Try adding a 2nd, and even maybe a 3rd copy of the terrain, with different textures and give them varying levels of morphs and see if you can get a good blend between them.
    Post edited by Lissa_xyz on
    Which renderer?
    If it's Iray, you can use decals/masks or topcoat...
    You can do the same with UberSurface 2 (not US) in 3Delight...it has a mix mode between the layers.
  • Widdershins StudioWiddershins Studio Posts: 572
    edited March 2016
    I'll try that but I thought it might be a bit jaggy.
    mjc1016 said:
    Which renderer?
    I need a solution for 3Delight and Iray. Do you jknow any tutorials ? I downloaded the one from Daz, but it is outdated and very basic.
    I thought maybe I could do something with the shader mixer, but have not really worked it out yet.
    Post edited by Widdershins Studio on
    Going the Shader Mixer route...there used to be a lot of good stuff that has gone away, but 3DCheapskate has a multi-layer ShaderMixer network with a good 'how to use' guide...
    Here's the guide: http://www.sharecg.com/v/71752/gallery/3/PDF-Tutorial/Using-The-DAZ-Studio-Shield-Shader
    And the network: http://www.sharecg.com/v/66637/gallery/21/DAZ-Studio/DAZ-Studio-Shader-For-S.E.Asian-Shields
  • Thanks a lot. I'll have a read :)
