DS Morphs set
wqwwqw Posts: 11
Hello everyone,
How to set up a morph directly from 0 to 1, but the process does not show, for example, I can set a morph show only three outcomes 0--0.5--1,but the process of Morph does not show.
Post edited by wqw on
  • Richard HaseltineRichard Haseltine Posts: 108,161
    Instead of bumping please explain in a bit more detail what it is you want.
  • wqwwqw Posts: 11
    When using Poser, I was able to open parameter dial settings and change the sensitivity to, let's say, 1.00, if I wanted a particular morph to simply go from 0 to 1 all at once, with no transforms in-between. This came in handy for certain types of morphs. Now I'm wanting to make the same edit to a morph dial in DS, and I've found the "sensitivity(Nudge)" setting, however, it does not seem to work in the same fashion.
