Pose Presets
j_stnkj_stnk Posts: 205
Hello,
I not quite sure how to make a pose preset for just the eyes. where in the hierarcy do i deselect or select for just the eyes in the pose preset dialog window?  thanks
  • AJ2112AJ2112 Posts: 1,417
    edited March 2016
    In the dialog box, click on the yellow arrow to uncheck all, then click on drop down arrows hip >  abdomen > chest > neck > head.  You will see r/l eye click both boxes.
    614 x 644 - 138K
    Post edited by AJ2112 on
  • j_stnkj_stnk Posts: 205
    Thanks, there were just too many other areas in the drop down tree like "hidden" "pose" "general" etc. it got it!
  • gederixgederix Posts: 390
    If you are looking for pose controls for the eyes, assuming they exist for the figure you are using, they will be in the parameters tab.
    Select the figure to get the pose controls to show, or the head specifically to get to the eye controls directly. Like so:
    http://www.daz3d.com/forums/uploads/FileUpload/6a/a43da00cd7dba51881d5484dc86f74.png
  • KimberSueKimberSue Posts: 353
    How did you get the "Pose Preset Save Options" windows open?
    edited March 2016
    Hi Kimber, select figure in scene tab, go to file > save as > pose preset, select a file name > save to your desired location, I use My library, once you save,to location, pose preset dialog options opens.  Click yellow check mark, to select none.  Expand each drop down arrow, till you see part you desire to save, place yellow check mark, click accept.
    thank you very much
    Your welcome.
