Saving pose presets
This discussion was created from comments split from: Second Life and Daz.
Hello, I'm using daz for poses and I'd like to save poses for furture use and adjustment. I can't seem to figure out how exactly to do this. Can anyone give me the steps needed to do this.
Thanks very much.
Try this: http://digi-dotz.com/index.php/tutorials/item/4-saving-partial-poses-in-daz-studio-4
http://sickleyield.deviantart.com/journal/Mini-Tutorial-Hierarchical-Presets-in-DAZ-Studio-503382249
Hi,
I started a discussion some time ago: http://www.daz3d.com/forums/discussion/41650/how-to-store-poses-globally#first
If saving a pose preset, you have to select the properties you want to save. To prevent the posed character to jump to the initial place, where you once created the pose, you have to deselect those globally positioning parameters.
If some adjustments of rotation / translation are necessary for the pose itself, apply these adjustments to the hip of the character. Most of the commercial pose products are created that way.
The attachmant shows my proposal.
Andy
BeeMay and AndyS, thanks for the responses. I should have noted that I'm specifically addressing the reuse of Second Life avatar poses. I'll look through your links and see if this does the trick. Thanks for responding.
Senna
