Halp! Half of toolbar missing?
jlc767jlc767 Posts: 0
I must have done something --- I've lost most of my toolbar at the top. You know, File, etc. I only see Tools and Window.
Halp!
    Windows > Workspace > Select Layout. Change it then change it back to what you had. It should reset it.
  • jlc767jlc767 Posts: 0
    I don't have those options in the Window tab.
  • Richard HaseltineRichard Haseltine Posts: 108,882
    Not tab, menu - it's just visible at top-left in your screenshot.
    Ummm. Can someone walk me through this or post a screenshot or something? I even uninstalled / reinstalled. And File (and the rest) aren't there to the left, because look - even if I minimize the window, Tools and Window are still flush left.
    605 x 442 - 156K
  • JaderailJaderail Posts: 0
    Window MENU. OPEN the Window MENU do Select LAYOUT pick a layout...
    411 x 284 - 21K
    Eh. What the hell did I do!? I don't even have those options in the Window tab.
    This is Daz Studio 4.6 Pro (64-bit), FYI.
    And the FULL status bar was definitely there last night before I managed to muck it all up.
    1280 x 1216 - 602K
    Your Configuration file for DAZ Studio has been corrupted. That is a File that lives from install to install unless hand removed from your PC. Let me hunt the proper file down. What is your OS? Win 7 64bit?
    Windows 7 Home Premium SP1 (64-bit)
    And thanks! :)
    Unfortunately I'm not 100% sure which file is the Config file only. I have sent out a help request for the info to the other Admin's. Please give me time to get the proper answer.
    C:\Users\You\AppData\Roaming\DAZ 3D\Studio4. With DS closed remove layout.dsx, menus.dsx, toolbars.dsx and actions.dsx then start DS.
    AppData is hidden by default - you may need to go to Folder Options in the control panel and enable the display of hidden files and folders to get there.
  • remuscatremuscat Posts: 1
    Richard, you are KING!
    Have been trying to resolve this for some time now without success, now it's back to normal....
    A big THANKS :)
    I'm glad that was useful.
  • Glad this was here... HUGE help!!
  • press f3 then click on defaults apply accept.
