3ds import jumbled
Trying to import a 3ds model and half of the model seems to be flipped around and moved. There's an obj included, but it lacks material zones.
Any thoughts?
  • StezzaStezza Posts: 8,831
    depending on the complexity of the model, I either try and put it back together or I use Hexagon, import it and then export it as a car file.. then open in Carrara
    If neither of them work then I ditch it and look for another model cool
    3ds files can be very tricky to work with.  It doesn't matter what you use to open them, not all will work in everything.  Some that are exploded in one program will be fine in another, so try a couple of different ones, before giving up on it.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,329
    try Poseray too
