Model disappearing?
Help! Whenever I move the camera or adjust sliders, the model kind of blinks out for a second and I can only see an outline. It's really annoying and makes it hard to make small adjustments. Is there a setting I can change or is this a glitch?
Post edited by mmm4466 on
Hi mmm4466...
Go to the Tool Settings pane and in the During Manipulation box change the DrawStyle to Use Current(off).
You can also change the other two settings just like in the image below and that will give you "real time" feed back while posing Genesis, but it can cause lag in the viewport if your scene is large or your video card is slow.
Hope this helps... :)
