Stella for Star
azoohouse
in The Commons
She refuses to get into my cart. It tells me she was added when she is not.
Reported
I'm getting the same thing. The numer of items in my cart goes up by one when I add her, but if I go to the cart or back to the store it goes down again.
I'm having the same problem.
Things have changed a bit. Last time I tried to add her she stayed in the cart, but when I went to the cart I had this error at the top: "Some of the products below do not have all the required options. " There was no checkout button avaialable.
Yep, me too. Perhaps they are working on it.
We are looking at it, should be solved soon.
Then it will be time to break out the Guiness to celebrate
Looks to be working, let me know if you see any other weirdnesses.
Works fine for me. Thank you for fixing it.
You mentioned other weirdnesses. This has nothing to do with the original problem or with buying Stella but I was a bit puzzled by the store description. It mentioned Daz Studio 3Delight and Iray material settings but it also said that she uses pmd morphs so only works in Poser. The download that I got was one zip file which contains a Poser style installation, i.e. everything in Runtime\libraries. I haven't tried using this in Daz Studio but I can't find any Studio native format .duf, .daz etc files and it has't got a "support" directory like some products have.
This isn't a problem fro me since I use both Poser and Daz Srudio, but I expect a lot of your customers are Studio only users so they need to know how Studio compatible Stella is.
