A big problem with Victoria 7
2»
    edited March 2016
    eg if I use DIM, as default setting,, it should install contents to the
    c::/ユーザー/パブリック/パブリックのドキュメント/MY DAZ 3D Library,  It is "path" which I can see in windows explorer.
    Then   if I set the same directory,, by Didrectory manager,,  it should be shown like that,, C:/Users/Public/documentsMY DAZ 3D Library,
    in daz studio Directory manager,, And it is same as the OP pic.. I can not find any difference about the path which he sets by directory manager.
    958 x 420 - 82K
    1236 x 588 - 114K
    Post edited by kitakoredaz on
    edited March 2016
    Then If I use directory "C:/Users/漢字とひらがなの名前(account of windows)/documents/Mylibaray"
    it usually cause problem, when I work with DB.  then I do not think it work with DIM, and migration process of database by ds 4.9
  • You have all to know that i have no problem like this with all my other characters (gnenesis 1 or 2)
    so if i have major troubles with genesis 3 i think i will just uninstall it
    i have everything i need with genesis 2
  • nonesuch00nonesuch00 Posts: 18,795
    I had trouble with Genesis 3 Female Essential too for a while I could not install properly and got the same problem you had. I uninstalled and reinstalled several times and it finally worked. Why, I don't know; but I do know I uninstalled Genesis 3 Female Essentials and deleted them from the DAZ Install Manager and redownloaded and installed a couple of times and it finally worked. I have no French language computer but I do usually have the keyboard set as Norwegian. However the OS and it's language system except the keyboard I/O is American English.
    There must a bug that happens sometimes with the Genesis 3 Female Essentials installation.
  • thanks for your help
    a technician from Daz Helpdesk is working on my problem now, i gave him the link of this page
    ced
  • LeanaLeana Posts: 12,905
    Hmm, the path in DS is C:\Users... but the path in your screenshot is C:\uiltisateurs... I wonder if that is the issue - DS is suing the English folder names literally, not expanding them to the local path name. Do you have a folder called C:\Users\Public on your system, and does it contain the Genesis 2 Female file that are working?
    "Utilisateurs" is just a lablel Windows uses for display, the physical path to that directory is actually C:\Users.
  • Richard HaseltineRichard Haseltine Posts: 109,054
    Ah, thank you Leana - I did wonder if that might be the case but being strictly Anglophone had no simple way to check.
