It has to be something simple.
I started a new composition and started setting things up and ran into this problem when I add poses to my figure.  The dress decides to ignore the legs of the model and just hang as it wants.  Anyone know what is causing this and how to fix it.
    For that particular dress it looks like the movement should be done with the various movement/adjustment morphs.
    With the dress selected, look in the Parameters tab for the various morphs.
  • Cris PalominoCris Palomino Posts: 12,671
    Are you using the included drape poses?  I believe this is Aave's dress you mean?
  • SilvertSilvert Posts: 46
    Dress is the Roanmara Gown.  I have the parameters open in the pic.  What should I be looking for.
    Expand Actor...there should be a bunch of shaping, fit, draping morphs under there...and maybe even some on the individual parts (like the skirt).
    Thinking about this and realized what the problem was.  The bones of the dress are not matching up with the bones of the legs.  I did this render a few weeks ago and did not have this problem.
    978 x 864 - 688K
    Unless the new update had something in it that I missed.  I think I know the problem but not the fix.
  • Richard HaseltineRichard Haseltine Posts: 109,187
    The bones may well not be meant to match the figure: as noted earlier there are morphs or controllers to drape the skirt, which - as is most often the case - needs to be done manually.
  • FirstBastionFirstBastion Posts: 8,054
    If you have a look at the product page there is a long list of adjustment morphs.  Select the dress and use the morphs to adjust to pose.
    • Roanmara (.DUF and .CR2)
      • Gown Adjustments:
        • Adjust Armholes
        • Adjust Buttocks
        • Adjust Left ForeArm
        • Adjust Hips
        • Adjust Hip_Left
        • Adjust Hip_Right
        • Adjust Left Collar
        • Adjust Left Shoulder
        • Adjust Left Thigh Side
        • Adjust Lower Back
        • Adjust Mid-Section
        • Adjust Right Collar
        • Adjust Right ForeArm
        • Adjust Right Shoulder
        • Adjust Right Thigh Side
        • Adjust Thighs
        • Adjust Uppper Torso
        • Adjust Waist
        • Adjust Waist_Left
        • Adjust Waist_Right
      • SkirtMovement Morphs:
        • All Skirt Bend
        • All Skirt Back
        • All Skirt Front
        • All Skirt Side-Side
        • All Skirt SideL
        • All Skirt SideR
        • All Skirt Twist Left
        • All Skirt Twist Right
        • All Skirt Twist
        • BackBottomOut
        • Back Out
        • Left Back
        • Right Back
        • Front In
        • Front Left Bottom In
        • Front Right Bottom In
        • Front Left Out
        • Front Out
        • Front Right Out
        • Lift Front Bottom
        • Blow Left
        • Blow Right
        • Climb Left
        • Climb Right
        • Left Bottom Side Out
        • Left Side In
        • Left Thigh Back
        • Right Bottom Right
        • Right Back
        • Right Side In
        • Right Side Out
        • Right Thigh Back
      • Skirt Morphs:
        • BottomFlare
        • Decrease Depth
        • Decrease Sides
        • Drape
        • DressLonger
        • DressShorter
        • Sit
        • Skirt Fullness
        • Train
      • Gown Supported Genesis 2 Female
