Fatal Error when tried to open or save file in Daz
I've been using daz3d for about 3 months, it was working properly and I'm happy with it
but yesterday suddenly when I tried to save a scene, daz crashed and showed that Daz has encountered a fatal error and must close.
DAZStudio.exe caused IN_PAGE_ERROR in module "C:\Windows\system32\COMDLG32.dll" at 0033:00000000FF9C4A00, PageSetupDlgA()+17696 byte(s)
I'm using 64 bit, here's my PC (Laptop) spec
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150928-1507)
Processor: Intel(R) Core(TM) i3-2370M CPU @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 3970MB RAM
NVIDIA Geforce 610M 2GB
I know my laptop is outdated, but for last 3 months it can run daz3d pretty smoothly with simple scenes
I started having them while deleting objects... (computer is not an issue dual xeons and 64 gigs)
but if you have the scene open
save often...
in the case of my crashes it was particular items* that were causing the crashes... so I could save other parts of the scene as a scene subset.
if you had a previous save of the scene... figure out what you did before the version that crashed..
if no previous saves... just set a timer or just save everytime you do something major...
*to find the problem, I just started deleting small parts until I found the one that crashed the scene...
I don't recall having as many crashes back with earlier verisons than the last couple...but I've done a lot more stuff the past couple of years...
I did have 4.7 crashing when trying to read in scenes that I created in 4.6 --- I was able to go back an open the scene with 4.6 and save different versions that I opened in 4.8 until I found what caused the crash and elimated it from the old scenes..
Thanks for your suggestion but I don't think the items in the scene is the issue here
Sorry I didn't explain it clearly before, I will elaborate my problem :
- I CAN open my files from recent files (file>open recent files)
- I CAN save (overwrite) my loaded scene from recent files
- I CAN render it
- When I try to save a scene as a new file (save as option) it CRASHES
- When I try to open a saved scene in my folder (file>open) it CRASHES
- Even I tried to save a blank scene as a new file, it still crash
In a nutshell, everytime I try to open files directory from my Daz, it crashes, but aside of that it runs fine
