clear timeline to start again
I'm using V4 and just experamenting how to animate her, in Daz studio Pro 4.9, and i'm just starting to use this and i'm wondering
how i go about clearing the timeline completly, i know you can delete, or how to delete frame by frame, but i need to know how to clear the
timeline so i dont have reload the character again to restart again
mm,, Select V4(with morphs) then top menu>edit>figure>clear animation>clear Figure (or pose or morph only)
not work for your puropose?
if you hope to delete all timeline key , you may need select all, then edit>Figure>clear Animation> clear selected items
though it can remove key which set for camera. (then turn default position)
If there are some you want to keep, you could save a range first, then clear all; then merge those you saved. For example if you didn't want the Camera clearing but was worried it might. File > Save as > Pose, then select the save as range option.
Thank you so much for your help.
